chattr -i /etc/mpd.conf
Nano /etc/mpd.conf
Add this to the active source:
format "192000:24:2"
samplerate_converter "soxr very high"
then :
Chattr +i /etc/mpd.conf
Example Content
name "bcm2835 ALSA_1"
device "hw:1,0"
dsd_usb "yes"
name "USB Audio DAC"
dsd_usb "yes"
format "192000:16:2"
Changes to /boot/config.txt
Rune Frost tells me that the changes in this file to the Dram and frequency settings add an 'analogue' sound to the output. Always a good thing...
Note: some of these values may be already present.
nano /boot/config.txt
max_usb_current=1
# memory options
#gpu_mem=64
gpu_mem=16
# Overclocking options
force_turbo=1
avoid_pwm_pll=1
arm_freq=666
over_voltage=-10
gpu_freq=333
# sdram overclock
sdram_freq=333
sdram_schmoo=0x02000020
over_voltage_sdram_p=-5
over_voltage_sdram_i=-14
over_voltage_sdram_c=-6
disable_pvt=1
# HDMI disable
hdmi_blanking=2
Please note: Rune Frost advises that when the ARM voltage is lower than -7, the integrated wi-fi will stop working. If wi-fi is required, you can still use an edimax (or similar) dongle for wi-fi. But going below -7 is quite noticeable.. perhaps it is because of the internal wifi/bluetooth is also then disabled
It should be noted that the best internet link is always an ethernet cable. If your router is not near your hi-fi, a good quality powerplug extender works well for the author, e.g. TP-Link AV500, or similar.
Changes to /boot/cmdline.txt
N.B. Some of these parameters are already present.
Nano /boot/cmdline.txt
dwc_otg.microframe_schedule=0
dwc_otg.nak_holdoff_enable=1
dwc_otg.fiq_fix_enable=0
dwc_otg.microframe_schedule=1
smsc95xx.turbo_mode=N
dwc_otg.lpm_enable=0
Orion Optimize Mods (/var/www/command/orion_optimize.sh)
nano /var/www/command/orion_optimize.sh
# common startup #
#if [ "$PID" != null ]; then
#echo "Set priority for: cifsd"
#renice -20 $PID
#fi
cifsprio pid=$(pidof cifsd)
echo "Set normal priority for: rune_SY_wrk"
renice 20 $(pgrep rune_SY_wrk)
echo "Set normal priority for: rune_PL_wrk"
renice 20 $(pgrep rune_PL_wrk)
echo "Set normal priority for: smbd"
renice 19 $(pidof smbd)
echo "Set normal priority for: nmbd"
renice 19 $(pidof nmbd)
#runeFrost
renice -10 -p 3
renice -10 -p 12
renice -10 -p 16
renice -10 -p 20
Also in /var/www/command/orion_optimize.sh
Find the Sound Profiles section (see below), then modify the ‘# mod 3’ section to look like following lines. This content replaces the original parameters so the original lines must be deleted. Alternatively, they can be commented out by putting a ‘#’ at the start of each line.
# Sound Profiles
# mod 3
if [ "$1" == "OrionV2" ]; then
# runefrost version
ifconfig eth0 mtu 9000
ifconfig wlan0 mtu 9000
ifconfig eth0 txqueuelen 4000
ifconfig wlan0 txqueuelen 4000
echo 0 > /proc/sys/vm/swappiness
modKschedLatency hw=$2 s01=120000 s02=2000000 s03=2000000 s04=2000000 s05=2000000 s06=2000000 s07=2000000 s08=2000000 s09=2000000 s10=2000000 u01=2 u02=2 u03=2 u04=2 u05=2 u06=2 u07=2 u08=2 u09=2 u10=2
#runeFrost
echo -n performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo -n performance > /sys/devices/system/cpu/cpu1/cpufreq/scaling_governor
echo -n performance > /sys/devices/system/cpu/cpu2/cpufreq/scaling_governor
echo 1000000 > /proc/sys/kernel/sched_latency_ns
echo 100000 > /proc/sys/kernel/sched_min_granularity_ns
echo 25000 > /proc/sys/kernel/sched_wakeup_granularity_ns
echo 1 > /proc/sys/kernel/hung_task_check_count
echo 20 > /proc/sys/vm/stat_interval
echo -1 > /proc/sys/kernel/sched_rt_runtime_us
echo 5 > /proc/sys/vm/dirty_background_ratio
sleep 2
mpdprio_nice
echo "(OrionV2) sound signature profile"
fi
