Hi bnilsson,
please check the mount options in /etc/udevil/udevil.conf.
Depending on the filesystem used on your thumb drive it may be set to RO.
# default_options specifies what options are always included when performing
# a mount, in addition to any options the user may specify.
# Note: When a device is present in /etc/fstab, and the user does not specify
# a mount point, the device is mounted with normal user permissions using
# the fstab entry, without these options.
# default_options_FSTYPE, if present, is used to override default_options
# when mounting a specific fstype (eg ext2, nfs).
# The variables $USER, $UID, and $GID are changed to the user's username, UID,
# and GID.
# FOR GOOD SECURITY, default_options SHOULD ALWAYS INCLUDE: nosuid,noexec,nodev
# WARNING: OPTIONS PRESENT OR MISSING CAN CAUSE SERIOUS SECURITY PROBLEMS.
default_options = nosuid, noexec, nodev, noatime
default_options_file = nosuid, noexec, nodev, noatime, uid=$UID, gid=$GID, rw
# mount iso9660 with 'ro' to prevent mount read-only warning
default_options_iso9660 = nosuid, noexec, nodev, noatime, uid=$UID, gid=$GID, rw, utf8
default_options_udf = nosuid, noexec, nodev, noatime, uid=$UID, gid=$GID
default_options_vfat = rw, iocharset=utf8, noatime, uid=$UID, gid=$GID
default_options_exfat = rw, nonempty, uid=$UID, gid=$GID
default_options_hfsplus = rw, uid=$UID, gid=$GID
default_options_msdos = nosuid, noexec, nodev, noatime, fmask=0133, dmask=0022, uid=$UID, gid=$GID
default_options_umsdos = nosuid, noexec, nodev, noatime, fmask=0133, dmask=0022, uid=$UID, gid=$GID
default_options_ntfs = nosuid, noexec, nodev, noatime, fmask=0133, uid=$UID, gid=$GID, utf8
default_options_cifs = nosuid, noexec, nodev, uid=$UID, gid=$GID
default_options_smbfs = nosuid, noexec, nodev, uid=$UID, gid=$GID
default_options_sshfs = nosuid, noexec, nodev, noatime, uid=$UID, gid=$GID, nonempty, allow_other
default_options_curlftpfs = nosuid, noexec, nodev, noatime, uid=$UID, gid=$GID, nonempty, allow_other
default_options_ftpfs = nosuid, noexec, nodev, noatime, uid=$UID, gid=$GID
default_options_davfs = nosuid, noexec, nodev, uid=$UID, gid=$GID
default_options_tmpfs = nosuid, noexec, nodev, noatime, uid=$UID, gid=$GID
default_options_ramfs = nosuid, noexec, nodev, noatime, uid=$UID, gid=$GID
The next version will have all these changes by default.
