Related to samba, I looked at the issue 13 on github
https://github.com/RuneAudio/RuneOS/issues/13
I whitnessed the same error as described. I did not find anything obvious, so I tried to build the latest 4.2.0. After removing lots of deprecated optons in ./configure, I stumbled on a make error
: ok
Checking linker accepts -Wl,-no-undefined : yes
Checking linker accepts ['-undefined', 'dynamic_lookup'] : no
Checking linker accepts -Wl,--as-needed : yes
Checking for -lc not needed : ok
Checking configure summary : ok
Checking compiler for PIE support : yes
Checking compiler for full RELRO support : yes
Checking for libsystemd-daemon : yes
Checking for header systemd/sd-daemon.h : yes
Checking for library systemd-daemon : yes
Checking compiler accepts ['-fstack-protector'] : yes
Checking linker accepts ['-fstack-protector'] : yes
'configure' finished successfully (16m47.100s)
Selected embedded Heimdal build
Checking project rules ...
Project rules pass
Unable to find build target matching make
==> ERROR: A failure occurred in build().
Aborting...
I didnt manage to understand that, and tried to compare with other PKGBUILD on the net, but they all seam very complicated
Then I tried to install 4.2.0 with pacman, and realised it only take 34MB extra
Plus, considering the RPI 2 replacing the RPI, the cpu/mem gain may be less important (or no relevant anymore) compared to effort of supporting a custom build ? So it may be a good move to get back using default samba and smbclient ?
What do you think ?
