hondagx35 wroteHi,
try:
amixer -c0 set 'Subwoofer mode' 'None'
and
amixer -c0 set 'Dual Mode' 'Dual-Mono'
on console.
thank you - already tried but does not work ->
root@runeaudio(rw):~# amixer -c0 set 'Subwoofer mode' 'None'
amixer: Invalid command!
root@runeaudio(rw):~# amixer -c0 set 'Dual Mode' 'Dual-Mono'
amixer: Unable to find simple control 'Dual Mode',0
root@runeaudio(rw):~# amixer -c 0 sset "Dual Mode" "Dual-Mono"
After researching, it seems that either RuneOS needs an more recent Linux kernel a/o the Piano DAC 2.1 an firmware update by ALLO (!?)
Here some outputs:
Using username "root".
=============== RuneOS distribution ===============
____ _ _ _
| _ \ _ _ _ __ ___ / \ _ _ __| (_) ___
| |_) | | | | '_ \ / _ \ / _ \| | | |/ _` | |/ _ \
| _ <| |_| | | | | __// ___ \ |_| | (_| | | (_) |
|_| \_\\__,_|_| |_|\___/_/ \_\__,_|\__,_|_|\___/
================ http://www.runeaudio.com ================
Hw-env: RaspberryPi 2 / 3
Last login: Thu May 17 19:02:24 2018 from 192.168.178.5
root@runeaudio(rw):~# cat /boot/config.txt
# Uncomment some or all of these to enable the optional hardware interfaces
# Params:
# i2c_arm Set to "on" to enable the ARM's i2c interface
# (default "off")
# i2c_vc Set to "on" to enable the i2c interface
# usually reserved for the VideoCore processor
# (default "off")
# i2c_arm_baudrate Set the baudrate of the ARM's i2c interface
# (default "100000")
# i2c_vc_baudrate Set the baudrate of the VideoCore i2c interface
# i2c_baudrate An alias for i2c_arm_baudrate
# i2s Set to "on" to enable the i2s interface
# (default "off")
# spi Set to "on" to enable the spi interfaces
# (default "off")
# act_led_trigger Choose which activity the LED tracks.
# Use "heartbeat" for a nice load indicator.
# (default "mmc")
# act_led_activelow Set to "on" to invert the sense of the LED
# (default "off")
# act_led_gpio Set which GPIO pin to use for the activity LED
# (in case you want to connect it to an external
# device)
# (default "16" on a non-Plus board, "47" on a
# Plus or Pi 2)
# N.B. It is recommended to only enable those interfaces that are needed.
# Leaving all interfaces enabled can lead to unwanted behaviour (i2c_vc
# interfering with Pi Camera, I2S and SPI hogging GPIO pins, etc.)
# Note also that i2c, i2c_arm and i2c_vc are aliases for the physical
# interfaces i2c0 and i2c1. Use of the numeric variants is still possible
# but deprecated because the ARM/VC assignments differ between board
# revisions. The same board-specific mapping applies to i2c_baudrate,
# and the other i2c baudrate parameters.
dtparam=i2c_arm=on
#dtparam=i2c_vc=on
dtparam=i2s=on
#dtparam=spi=on
#dtparam=act_led_trigger=mmc
#dtdebug=on
#dtparam=uart1=off
#dtoverlay=pi3-disable-bt-overlay
#dtoverlay=pi3-miniuart-bt-overlay
## RuneAudio HDMI & 3,5mm jack
dtparam=audio=off
## RuneAudio I2S-Settings
dtoverlay=allo-piano-dac-plus-pcm512x-audio,glb_mclk
# Uncomment to enable the lirc-rpi module
# Params: gpio_out_pin GPIO pin for output (default "17")
# gpio_in_pin GPIO pin for input (default "18")
# gpio_in_pull Pull up/down/off on the input pin
# (default "down")
# sense Override the IR receive auto-detection logic:
# "1" = force active high
# "0" = force active low
# "-1" = use auto-detection
# (default "-1")
# softcarrier Turn the software carrier "on" or "off"
# (default "on")
# invert "on" = invert the output pin (default "off")
# debug "on" = enable additional debug messages
# (default "off")
#dtoverlay=lirc-rpi
#dtparam=gpio_out_pin=17
#dtparam=gpio_in_pin=18
#dtparam=gpio_in_pull=down
# LCD settings
# 180 degrees
#lcd_rotate=2
# Normal
lcd_rotate=0
#dtoverlay=rpi-backlight
#dtoverlay=rpi-ft5406
disable_splash=1
# Uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# Uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# Uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# Uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# Uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# Uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# Uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=2
# Uncomment to set monitor mode to DMT
#hdmi_group=2
# Uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# setting the max usb current to 1200mA
max_usb_current=1
# memory options
gpu_mem=64
# Overclocking options
force_turbo=1
root@runeaudio(rw):~# ls -l /boot/overlays/allo*
-rwxr-xr-x 1 root root 1381 Feb 11 2017 /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo
-rwxr-xr-x 1 root root 1011 Feb 11 2017 /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo
-rwxr-xr-x 1 root root 1357 Feb 11 2017 /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo
Linux version 4.4.39-ARCH+ (frank@franks-ubuntu) (gcc version 4.8.3 20140106 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.01 - Linaro GCC 2013.11) ) #5 SMP Sat Feb 11 15:43:36 CET 2017
system time: Tue May 15 19:45:34 CEST 2018
system load: 0.11 0.05 0.01 2/150 7655
HW platform: RaspberryPi2 (08)
playerID: 08b26fff2ac4ddac6fee7fbbc1890504ae
systemd-+-avahi-daemon---avahi-daemon
|-dbus-daemon
|-dnsmasq
|-haveged
|-ifplugd
|-mpd-+-{decoder:mad}
| |-{io}
| |-{output:PianoDAC}
| `-{player}
|-nginx---nginx
|-nmbd
|-ntpd---{ntpd}
|-php-fpm---3*[php-fpm]
|-python
|-rune_PL_wrk
|-rune_SY_wrk---sh---debug_collector---sh---pstree
|-sh---sleep
|-smbd---smbd
|-sshd---sshd---bash
|-systemd-journal
|-systemd-udevd
`-upmpdcli---8*[{upmpdcli}]
Advanced Linux Sound Architecture Driver Version k4.4.39-ARCH+.
0 [PianoDACPlus ]: PianoDACPlus - PianoDACPlus
PianoDACPlus
PLAYBACK devices: (aplay -l)
card 0: PianoDACPlus [PianoDACPlus], device 0: PianoDACPlus multicodec-0 []
Subdevices: 0/1
Subdevice #0: subdevice #0
PCM devices: (aplay -L)
null
default:CARD=PianoDACPlus
PianoDACPlus,
Default Audio Device
sysdefault:CARD=PianoDACPlus
PianoDACPlus,
card 0:
Simple mixer control 'DSP Program',0
Simple mixer control 'Analogue',0
Simple mixer control 'Analogue Playback Boost',0
Simple mixer control 'Auto Mute',0
Simple mixer control 'Auto Mute Mono',0
Simple mixer control 'Auto Mute Time Left',0
Simple mixer control 'Auto Mute Time Right',0
Simple mixer control 'Clock Missing Period',0
Simple mixer control 'Deemphasis',0
Simple mixer control 'Digital',0
Simple mixer control 'Lowpass',0
Simple mixer control 'Max Overclock DAC',0
Simple mixer control 'Max Overclock DSP',0
Simple mixer control 'Max Overclock PLL',0
Simple mixer control 'Subwoofer',0
Simple mixer control 'Subwoofer mode',0
Simple mixer control 'Volume Ramp Down Emergency Rate',0
Simple mixer control 'Volume Ramp Down Emergency Step',0
Simple mixer control 'Volume Ramp Down Rate',0
Simple mixer control 'Volume Ramp Down Step',0
Simple mixer control 'Volume Ramp Up Rate',0
Simple mixer control 'Volume Ramp Up Step',0
card 0:
numid=6,iface=MIXER,name='DSP Program'
numid=3,iface=MIXER,name='Analogue Playback Boost Volume'
numid=2,iface=MIXER,name='Analogue Playback Volume'
numid=10,iface=MIXER,name='Auto Mute Mono Switch'
numid=11,iface=MIXER,name='Auto Mute Switch'
numid=8,iface=MIXER,name='Auto Mute Time Left'
numid=9,iface=MIXER,name='Auto Mute Time Right'
numid=7,iface=MIXER,name='Clock Missing Period'
numid=5,iface=MIXER,name='Deemphasis Switch'
numid=4,iface=MIXER,name='Digital Playback Switch'
numid=1,iface=MIXER,name='Digital Playback Volume'
numid=22,iface=MIXER,name='Lowpass Route'
numid=20,iface=MIXER,name='Max Overclock DAC'
numid=19,iface=MIXER,name='Max Overclock DSP'
numid=18,iface=MIXER,name='Max Overclock PLL'
numid=24,iface=MIXER,name='Subwoofer Playback Switch'
numid=23,iface=MIXER,name='Subwoofer Playback Volume'
numid=21,iface=MIXER,name='Subwoofer mode Route'
numid=16,iface=MIXER,name='Volume Ramp Down Emergency Rate'
numid=17,iface=MIXER,name='Volume Ramp Down Emergency Step'
numid=12,iface=MIXER,name='Volume Ramp Down Rate'
numid=13,iface=MIXER,name='Volume Ramp Down Step'
numid=14,iface=MIXER,name='Volume Ramp Up Rate'
numid=15,iface=MIXER,name='Volume Ramp Up Step'
Output 1 (PianoDACPlus) is enabled
MPD statistics: (mpc stats)
Artists: 2642
Albums: 2313
Songs: 8393
Play Time: 1 days, 22:56:14
Uptime: 6 days, 0:34:40
DB Updated: Sat Apr 14 20:07:35 2018
DB Play Time: 39 days, 3:42:55
###### mpd version ######
Music Player Daemon 0.19.19-dsd
Copyright (C) 2003-2007 Warren Dukes
Copyright (C) 2008-2014 Max Kellermann
This is free software; see the source for copying conditions. There is NO
warranty; not even MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Database plugins:
simple proxy upnp
Storage plugins:
local smbclient nfs
Neighbor plugins:
smbclient upnp
Decoders plugins:
[mad] mp3 mp2
[vorbis] ogg oga
[oggflac] ogg oga
[flac] flac
[sndfile] wav aiff aif au snd paf iff svx sf voc w64 pvf xi htk caf sd2
[audiofile] wav au aiff aif
[dsdiff] dff
[dsf] dsf
[faad] aac
[ffmpeg] 16sv 3g2 3gp 4xm 8svx aa3 aac ac3 afc aif aifc aiff al alaw amr anim apc ape asf atrac au aud avi avm2 avs bap bfi c93 cak cin cmv cpk daud dct divx dts dv dvd dxa eac3 film flac flc fli fll flx flv g726 gsm gxf iss m1v m2v m2t m2ts m4a m4b m4v mad mj2 mjpeg mjpg mka mkv mlp mm mmf mov mp+ mp1 mp2 mp3 mp4 mpc mpeg mpg mpga mpp mpu mve mvi mxf nc nsv nut nuv oga ogm ogv ogx oma ogg omg opus psp pva qcp qt r3d ra ram rl2 rm rmvb roq rpl rvc shn smk snd sol son spx str swf tak tgi tgq tgv thp ts tsp tta xa xvid uv uv2 vb vid vob voc vp6 vmd wav webm wma wmv wsaud wsvga wv wve
[pcm]
Output plugins:
null fifo pipe alsa jack httpd
Encoder plugins:
null vorbis wave flac
Input plugins:
file alsa curl ffmpeg smbclient nfs mms
Playlist plugins:
extm3u m3u pls xspf asx rss soundcloud cue embcue
Protocols:
file:// http:// https:// mms:// mmsh:// mmst:// mmsu:// gopher:// rtp:// rtsp:// rtmp:// rtmpt:// rtmps:// smb:// nfs:// alsa://
zeroconf_name "runeaudio"
auto_update "no"
audio_buffer_size "2048"
buffer_before_play "10%"
mixer_type "disabled"
replaygain "off"
audio_output_format "*:16:*"
name "PianoDACPlus"
hardware platform: RaspberryPi2
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 4500000
/proc/sys/kernel/sched_rr_timeslice_ms: 10
total 8.0K
drwxr-xr-x 2 root root 4.0K Jun 14 2017 .
drwxr-xr-x 6 root root 4.0K Dec 15 2016 ..
lrwxrwxrwx 1 root root 44 Jan 29 2017 amixer-webui.service -> /usr/lib/systemd/system/amixer-webui.service
lrwxrwxrwx 1 root root 47 Jun 14 2017 netctl-ifplugd@eth0.service -> /usr/lib/systemd/system/netctl-ifplugd@.service
lrwxrwxrwx 1 root root 36 Feb 15 2015 ntpd.service -> /usr/lib/systemd/system/ntpd.service
devtmpfs /dev devtmpfs rw,relatime,size=468036k,nr_inodes=117009,mode=755 0 0
cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct 0 0
tmpfs /tmp tmpfs rw 0 0
//192.168.178.3/music/music2/Hifi\040Concept /mnt/MPD/NAS/Hifi\040Center\040Music cifs ro,relatime,vers=1.0,sec=ntlm,cache=none,username=admin,uid=1000,forceuid,gid=92,forcegid,addr=192.168.178.3,unix,posixpaths,mapposix,acl,rsize=16384,wsize=17408,actimeo=1 0 0
//192.168.178.3/music/music2/Hifi\040Home\040Tracks /mnt/MPD/NAS/Hifi\040Home\040Tracks cifs ro,relatime,vers=1.0,sec=ntlm,cache=none,username=admin,uid=1000,forceuid,gid=92,forcegid,addr=192.168.178.3,unix,posixpaths,mapposix,acl,rsize=16384,wsize=17408,actimeo=1 0 0
//192.168.178.3/music/music2/X_SPOTIFYRIP /mnt/MPD/NAS/Spotify\040Rip cifs ro,relatime,vers=1.0,sec=ntlm,cache=none,username=admin,uid=1000,forceuid,gid=92,forcegid,addr=192.168.178.3,unix,posixpaths,mapposix,acl,rsize=16384,wsize=17408,actimeo=1 0 0
###### Loaded kernel modules ######
Module Size Used by
iptable_filter 1708 1
xt_conntrack 2972 1
ipt_MASQUERADE 1235 1
nf_nat_masquerade_ipv4 2915 1 ipt_MASQUERADE
iptable_nat 1943 1
nf_conntrack_ipv4 13702 2
nf_defrag_ipv4 1677 1 nf_conntrack_ipv4
nf_nat_ipv4 5699 1 iptable_nat
nf_nat 15862 2 nf_nat_ipv4,nf_nat_masquerade_ipv4
nf_conntrack 101212 5 nf_nat,nf_nat_ipv4,xt_conntrack,nf_nat_masquerade_ipv4,nf_conntrack_ipv4
cfg80211 498228 0
md4 3599 0
nls_utf8 1419 1
cifs 392255 2
snd_soc_pcm512x_i2c 2609 2
snd_soc_pcm512x 18826 1 snd_soc_pcm512x_i2c
regmap_i2c 3560 1 snd_soc_pcm512x_i2c
snd_soc_allo_piano_dac_plus 7018 1
snd_soc_allo_piano_dac 3417 0
snd_soc_bcm2835_i2s 6278 2
snd_soc_core 153224 4 snd_soc_allo_piano_dac_plus,snd_soc_pcm512x,snd_soc_bcm2835_i2s,snd_soc_allo_piano_dac
snd_pcm_dmaengine 5503 1 snd_soc_core
snd_pcm 88980 6 snd_soc_allo_piano_dac_plus,snd_soc_pcm512x,snd_soc_core,snd_soc_allo_piano_dac,snd_pcm_dmaengine
snd_timer 22172 1 snd_pcm
snd 63333 4 snd_soc_core,snd_timer,snd_pcm
bcm2835_rng 2167 0
i2c_bcm2708 5382 0
rng_core 8183 1 bcm2835_rng
bcm2835_gpiomem 3638 0
bcm2835_wdt 3756 0
uio_pdrv_genirq 3539 0
uio 9114 1 uio_pdrv_genirq
sch_fq_codel 8174 2
ip_tables 12147 2 iptable_filter,iptable_nat
x_tables 18169 4 ip_tables,ipt_MASQUERADE,xt_conntrack,iptable_filter
ipv6 372060 0
tcp 0 0 0.0.0.0:6600 0.0.0.0:* LISTEN 516/mpd
tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 452/smbd
tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 315/redis-server 12
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 743/python
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 329/nginx: master p
tcp 0 0 0.0.0.0:81 0.0.0.0:* LISTEN 329/nginx: master p
tcp 0 0 0.0.0.0:82 0.0.0.0:* LISTEN 329/nginx: master p
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 781/dnsmasq
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 300/sshd
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 452/smbd
tcp 0 0 0.0.0.0:49152 0.0.0.0:* LISTEN 520/upmpdcli
udp 0 0 127.0.0.1:53 0.0.0.0:* 781/dnsmasq
udp 0 0 0.0.0.0:67 0.0.0.0:* 781/dnsmasq
udp 0 0 127.0.0.1:44108 0.0.0.0:* 520/upmpdcli
udp 0 0 192.168.178.4:123 0.0.0.0:* 317/ntpd
udp 0 0 127.0.0.1:123 0.0.0.0:* 317/ntpd
udp 0 0 0.0.0.0:123 0.0.0.0:* 317/ntpd
udp 0 0 192.168.178.255:137 0.0.0.0:* 476/nmbd
udp 0 0 192.168.178.4:137 0.0.0.0:* 476/nmbd
udp 0 0 0.0.0.0:137 0.0.0.0:* 476/nmbd
udp 0 0 192.168.178.255:138 0.0.0.0:* 476/nmbd
udp 0 0 192.168.178.4:138 0.0.0.0:* 476/nmbd
udp 0 0 0.0.0.0:138 0.0.0.0:* 476/nmbd
udp 0 0 0.0.0.0:44243 0.0.0.0:* 304/avahi-daemon: r
udp 0 0 0.0.0.0:5353 0.0.0.0:* 304/avahi-daemon: r
udp 0 0 0.0.0.0:1900 0.0.0.0:* 520/upmpdcli
unix 2 [ ACC ] STREAM LISTENING 9480 1/init /run/systemd/private
unix 2 [ ACC ] STREAM LISTENING 12831 516/mpd /run/mpd.sock
unix 2 [ ACC ] STREAM LISTENING 11059 550/php-fpm: master /var/run/php-display.sock
unix 2 [ ACC ] STREAM LISTENING 11062 550/php-fpm: master /var/run/php-db.sock
unix 2 [ ACC ] STREAM LISTENING 11065 550/php-fpm: master /var/run/php-command.sock
unix 2 [ ACC ] SEQPACKET LISTENING 9530 1/init /run/udev/control
unix 2 [ ACC ] STREAM LISTENING 10086 1/init /var/run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 10088 1/init /run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 10091 1/init /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 9096 315/redis-server 12 /tmp/redis.sock
unix 2 [ ACC ] SEQPACKET LISTENING 1181 1/init /run/systemd/coredump
unix 2 [ ACC ] STREAM LISTENING 1184 1/init /run/systemd/journal/stdout
unix 2 [ ACC ] STREAM LISTENING 12730 476/nmbd /var/run/samba/nmbd/unexpected
###### List all USB devices (lsusb) ######
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
###### Kernel status (dmesg) ######
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.39-ARCH+ (frank@franks-ubuntu) (gcc version 4.8.3 20140106 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.01 - Linaro GCC 2013.11) ) #5 SMP Sat Feb 11 15:43:36 CET 2017
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 80ba3e80, node_mem_map b9fa6000
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9460->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @b9f62000 s22656 r8192 d22400 u53248
[ 0.000000] pcpu-alloc: s22656 r8192 d22400 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0x2a01041 bcm2709.serial=0x660c6e8 smsc95xx.macaddr=B8:27:EB:60:C6:E8 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rw rootwait rootfstype=ext4 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x3 elevator=noop ipv6.disable=1 logo.nologo quiet loglevel=3 rd.systemd.show_status=false rd.udev.log-priority=3
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 936072K/966656K available (8027K kernel code, 578K rwdata, 2900K rodata, 440K init, 797K bss, 22392K reserved, 8192K cma-reserved)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80ab3f68 (10928 kB)
.init : 0x80ab4000 - 0x80b22000 ( 440 kB)
.data : 0x80b22000 - 0x80bb2bd8 ( 579 kB)
.bss : 0x80bb5000 - 0x80c7c428 ( 798 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000021] Switching to timer-based delay loop, resolution 52ns
[ 0.000247] Console: colour dummy device 80x30
[ 0.000383] console [tty0] enabled
[ 0.000412] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000427] pid_max: default: 32768 minimum: 301
[ 0.000678] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000693] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001582] Disabling cpuset control group subsystem
[ 0.001615] Initializing cgroup subsys io
[ 0.001638] Initializing cgroup subsys memory
[ 0.001682] Initializing cgroup subsys devices
[ 0.001701] Initializing cgroup subsys freezer
[ 0.001717] Initializing cgroup subsys net_cls
[ 0.001731] Initializing cgroup subsys perf_event
[ 0.001745] Initializing cgroup subsys net_prio
[ 0.001774] Initializing cgroup subsys pids
[ 0.001827] CPU: Testing write buffer coherency: ok
[ 0.002352] CPU0: update cpu_capacity 1024
[ 0.002366] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.002374] [bcm2709_smp_prepare_cpus] enter
[ 0.002476] Setting up static identity map for 0x8240 - 0x8274
[ 0.004237] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.004550] [bcm2709_secondary_init] enter cpu:1
[ 0.004592] CPU1: update cpu_capacity 1024
[ 0.004597] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.005008] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.005230] [bcm2709_secondary_init] enter cpu:2
[ 0.005249] CPU2: update cpu_capacity 1024
[ 0.005254] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.005608] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.005831] [bcm2709_secondary_init] enter cpu:3
[ 0.005848] CPU3: update cpu_capacity 1024
[ 0.005853] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.005911] Brought up 4 CPUs
[ 0.005930] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.005936] CPU: All CPU(s) started in HYP mode.
[ 0.005941] CPU: Virtualization extensions available.
[ 0.006628] devtmpfs: initialized
[ 0.015237] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.015578] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.016134] xor: measuring software checksum speed
[ 0.110001] arm4regs : 1248.400 MB/sec
[ 0.210063] 8regs : 730.800 MB/sec
[ 0.310123] 32regs : 631.600 MB/sec
[ 0.410180] neon : 1214.000 MB/sec
[ 0.410189] xor: using function: arm4regs (1248.400 MB/sec)
[ 0.410310] pinctrl core: initialized pinctrl subsystem
[ 0.410866] NET: Registered protocol family 16
[ 0.415765] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.421194] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.421209] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.421345] Serial: AMBA PL011 UART driver
[ 0.421553] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.421975] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.650702] raid6: int32x1 gen() 134 MB/s
[ 0.820627] raid6: int32x1 xor() 108 MB/s
[ 0.990754] raid6: int32x2 gen() 175 MB/s
[ 1.160847] raid6: int32x2 xor() 115 MB/s
[ 1.330898] raid6: int32x4 gen() 179 MB/s
[ 1.501015] raid6: int32x4 xor() 116 MB/s
[ 1.671211] raid6: int32x8 gen() 168 MB/s
[ 1.841263] raid6: int32x8 xor() 108 MB/s
[ 2.011423] raid6: neonx1 gen() 441 MB/s
[ 2.181479] raid6: neonx1 xor() 321 MB/s
[ 2.351592] raid6: neonx2 gen() 578 MB/s
[ 2.521727] raid6: neonx2 xor() 416 MB/s
[ 2.691845] raid6: neonx4 gen() 721 MB/s
[ 2.861928] raid6: neonx4 xor() 480 MB/s
[ 3.032141] raid6: neonx8 gen() 476 MB/s
[ 3.202183] raid6: neonx8 xor() 342 MB/s
[ 3.202190] raid6: using algorithm neonx4 gen() 721 MB/s
[ 3.202197] raid6: .... xor() 480 MB/s, rmw enabled
[ 3.202203] raid6: using intx1 recovery algorithm
[ 3.203593] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 3.204067] SCSI subsystem initialized
[ 3.204331] usbcore: registered new interface driver usbfs
[ 3.204402] usbcore: registered new interface driver hub
[ 3.204525] usbcore: registered new device driver usb
[ 3.206957] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-12-09 15:11
[ 3.234229] clocksource: Switched to clocksource arch_sys_counter
[ 3.279299] FS-Cache: Loaded
[ 3.279552] CacheFiles: Loaded
[ 3.289262] NET: Registered protocol family 2
[ 3.290052] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 3.290159] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 3.290296] TCP: Hash tables configured (established 8192 bind 8192)
[ 3.290395] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 3.290446] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 3.290686] NET: Registered protocol family 1
[ 3.291014] RPC: Registered named UNIX socket transport module.
[ 3.291025] RPC: Registered udp transport module.
[ 3.291031] RPC: Registered tcp transport module.
[ 3.291037] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.292094] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 3.294544] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 3.304751] VFS: Disk quotas dquot_6.6.0
[ 3.304976] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 3.306900] FS-Cache: Netfs 'nfs' registered for caching
[ 3.307614] NFS: Registering the id_resolver key type
[ 3.307676] Key type id_resolver registered
[ 3.307684] Key type id_legacy registered
[ 3.307711] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 3.308368] JFS: nTxBlock = 7377, nTxLock = 59016
[ 3.315637] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 3.322124] async_tx: api initialized (async)
[ 3.322382] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 3.322538] io scheduler noop registered (default)
[ 3.322556] io scheduler deadline registered
[ 3.322612] io scheduler cfq registered
[ 3.324518] BCM2708FB: allocated DMA memory fac00000
[ 3.324551] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 3.331972] Console: switching to colour frame buffer device 82x26
[ 3.336693] vc-cma: Videocore CMA driver
[ 3.336703] vc-cma: vc_cma_base = 0x00000000
[ 3.336710] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 3.336716] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 3.336875] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 3.350313] brd: module loaded
[ 3.357690] loop: module loaded
[ 3.358502] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ 3.359949] Loading iSCSI transport class v2.0-870.
[ 3.360600] usbcore: registered new interface driver ax88179_178a
[ 3.360682] usbcore: registered new interface driver smsc95xx
[ 3.360801] usbcore: registered new interface driver cdc_ncm
[ 3.360817] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 3.561074] Core Release: 2.80a
[ 3.561088] Setting default values for core params
[ 3.561123] Finished setting default values for core params
[ 3.761384] Using Buffer DMA mode
[ 3.761394] Periodic Transfer Interrupt Enhancement - disabled
[ 3.761400] Multiprocessor Interrupt Enhancement - disabled
[ 3.761407] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.761425] Dedicated Tx FIFOs mode
[ 3.761724] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ 3.761753] FIQ FSM acceleration enabled for :
Periodic Split Transactions
[ 3.761767] dwc_otg: Microframe scheduler enabled
[ 3.761807] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x805d4318
[ 3.761819] WARN::hcd_init_fiq:414: FIQ ASM at 0x805d4660 length 36
[ 3.761830] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbbc7c000
[ 3.761883] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.761916] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.761949] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 3.761993] Init: Port Power? op_state=1
[ 3.762000] Init: Power Port (0)
[ 3.762195] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.762207] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.762217] usb usb1: Product: DWC OTG Controller
[ 3.762226] usb usb1: Manufacturer: Linux 4.4.39-ARCH+ dwc_otg_hcd
[ 3.762236] usb usb1: SerialNumber: 3f980000.usb
[ 3.762883] hub 1-0:1.0: USB hub found
[ 3.762922] hub 1-0:1.0: 1 port detected
[ 3.763439] dwc_otg: FIQ enabled
[ 3.763448] dwc_otg: NAK holdoff enabled
[ 3.763454] dwc_otg: FIQ split-transaction FSM enabled
[ 3.763483] Module dwc_common_port init
[ 3.763739] usbcore: registered new interface driver usb-storage
[ 3.763799] usbcore: registered new interface driver ums-alauda
[ 3.763851] usbcore: registered new interface driver ums-cypress
[ 3.763902] usbcore: registered new interface driver ums-datafab
[ 3.763952] usbcore: registered new interface driver ums_eneub6250
[ 3.764001] usbcore: registered new interface driver ums-freecom
[ 3.764053] usbcore: registered new interface driver ums-isd200
[ 3.764104] usbcore: registered new interface driver ums-jumpshot
[ 3.764155] usbcore: registered new interface driver ums-karma
[ 3.764207] usbcore: registered new interface driver ums-onetouch
[ 3.764314] usbcore: registered new interface driver ums-realtek
[ 3.764375] usbcore: registered new interface driver ums-sddr09
[ 3.764429] usbcore: registered new interface driver ums-sddr55
[ 3.764481] usbcore: registered new interface driver ums-usbat
[ 3.764737] mousedev: PS/2 mouse device common for all mice
[ 3.765344] md: linear personality registered for level -1
[ 3.765361] md: raid0 personality registered for level 0
[ 3.765375] md: raid1 personality registered for level 1
[ 3.765388] md: raid10 personality registered for level 10
[ 3.765622] md: raid6 personality registered for level 6
[ 3.765632] md: raid5 personality registered for level 5
[ 3.765639] md: raid4 personality registered for level 4
[ 3.765654] md: multipath personality registered for level -4
[ 3.765668] md: faulty personality registered for level -5
[ 3.765952] device-mapper: uevent: version 1.0.3
[ 3.766349] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.766898] device-mapper: multipath: version 1.10.0 loaded
[ 3.766920] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 3.766934] device-mapper: multipath queue-length: version 0.1.0 loaded
[ 3.766947] device-mapper: multipath service-time: version 0.2.0 loaded
[ 3.766977] device-mapper: raid: Loading target version 1.7.0
[ 3.767145] bcm2835-cpufreq: min=900000 max=900000
[ 3.767447] sdhci: Secure Digital Host Controller Interface driver
[ 3.767455] sdhci: Copyright(c) Pierre Ossman
[ 3.767761] sdhost: log_buf @ bac13000 (fac13000)
[ 3.824262] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.824463] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.824935] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.825108] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.825466] usbcore: registered new interface driver usbhid
[ 3.825474] usbhid: USB HID core driver
[ 3.825935] Initializing XFRM netlink socket
[ 3.825966] NET: Registered protocol family 17
[ 3.826093] Key type dns_resolver registered
[ 3.826680] Registering SWP/SWPB emulation handler
[ 3.827412] registered taskstats version 1
[ 3.830215] Btrfs loaded
[ 3.831362] Key type encrypted registered
[ 3.831457] vc-sm: Videocore shared memory driver
[ 3.831469] [vc_sm_connected_init]: start
[ 3.844764] [vc_sm_connected_init]: end - returning 0
[ 3.844950] of_cfs_init
[ 3.845044] of_cfs_init: OK
[ 3.845738] md: Waiting for all devices to be available before autodetect
[ 3.845747] md: If you don't use raid, use raid=noautodetect
[ 3.846655] md: Autodetecting RAID arrays.
[ 3.846666] md: Scanned 0 and added 0 devices.
[ 3.846671] md: autorun ...
[ 3.846676] md: ... autorun DONE.
[ 3.846819] Waiting for root device /dev/mmcblk0p2...
[ 3.902888] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.905373] mmc0: new high speed SDHC card at address 8fe4
[ 3.905963] mmcblk0: mmc0:8fe4 SU16G 14.8 GiB
[ 3.907839] mmcblk0: p1 p2
[ 3.954338] Indeed it is in host mode hprt0 = 00021501
[ 3.972686] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.972739] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.981861] devtmpfs: mounted
[ 3.982362] Freeing unused kernel memory: 440K (80ab4000 - 80b22000)
[ 4.134280] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 4.134434] Indeed it is in host mode hprt0 = 00001101
[ 4.304001] systemd[1]: System time before build time, advancing clock.
[ 4.334503] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 4.334519] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.335208] hub 1-1:1.0: USB hub found
[ 4.335299] hub 1-1:1.0: 5 ports detected
[ 4.413496] IPv6: Loaded, but administratively disabled, reboot required to enable
[ 4.424283] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.430191] random: systemd: uninitialized urandom read (16 bytes read, 48 bits of entropy available)
[ 4.442126] random: systemd: uninitialized urandom read (16 bytes read, 50 bits of entropy available)
[ 4.445323] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 4.445853] systemd[1]: Detected architecture arm.
[ 4.447106] systemd[1]: Set hostname to .
[ 4.520233] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 60 bits of entropy available)
[ 4.520567] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 60 bits of entropy available)
[ 4.527433] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 61 bits of entropy available)
[ 4.614277] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.617104] random: systemd: uninitialized urandom read (16 bytes read, 63 bits of entropy available)
[ 4.617412] random: systemd: uninitialized urandom read (16 bytes read, 63 bits of entropy available)
[ 4.617948] random: systemd: uninitialized urandom read (16 bytes read, 63 bits of entropy available)
[ 4.618889] random: systemd: uninitialized urandom read (16 bytes read, 63 bits of entropy available)
[ 4.642044] random: systemd: uninitialized urandom read (16 bytes read, 63 bits of entropy available)
[ 4.714525] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 4.714544] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.717301] smsc95xx v1.0.4
[ 4.776975] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:60:c6:e8
[ 4.970282] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.975014] systemd[1]: Listening on Process Core Dump Socket.
[ 4.975220] systemd[1]: Listening on udev Kernel Socket.
[ 4.975521] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.975757] systemd[1]: Listening on Journal Socket.
[ 4.996741] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.996860] systemd[1]: Reached target Login Prompts.
[ 4.996944] systemd[1]: Reached target Encrypted Volumes.
[ 4.997017] systemd[1]: Reached target Swap.
[ 4.997234] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 4.997334] systemd[1]: Reached target Remote File Systems.
[ 4.998106] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.000116] systemd[1]: Created slice System Slice.
[ 5.054861] systemd[1]: Starting RuneAudio shutdown script...
[ 5.058151] systemd[1]: Mounting Debug File System...
[ 5.062443] systemd[1]: Starting Setup Virtual Console...
[ 5.088570] systemd[1]: Mounting Temporary Directory...
[ 5.089880] systemd[1]: Created slice system-netctl\x2difplugd.slice.
[ 5.094707] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 5.109527] systemd[1]: Starting Load Kernel Modules...
[ 5.109758] systemd[1]: Reached target Slices.
[ 5.113548] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.114451] systemd[1]: Reached target System Time Synchronized.
[ 5.114945] systemd[1]: Listening on udev Control Socket.
[ 5.119103] systemd[1]: Starting Journal Service...
[ 5.119669] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.119879] systemd[1]: Reached target Paths.
[ 5.143199] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.160952] systemd[1]: Started RuneAudio shutdown script.
[ 5.162442] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 5.163762] systemd[1]: Started Load Kernel Modules.
[ 5.165164] systemd[1]: Started Remount Root and Kernel File Systems.
[ 5.209837] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.210195] systemd[1]: Mounted Debug File System.
[ 5.210433] systemd[1]: Mounted Temporary Directory.
[ 5.314564] systemd[1]: Started Journal Service.
[ 6.407600] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 6.413556] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 6.436981] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 83) (baudrate 100000)
[ 6.437460] bcm2835-rng 3f104000.rng: hwrng registered
[ 6.575839] snd-allo-piano-dac-plus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered
[ 6.575871] snd-allo-piano-dac-plus soc:sound: snd_soc_register_card() failed: -517
[ 6.653794] snd-allo-piano-dac-plus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered
[ 6.653820] snd-allo-piano-dac-plus soc:sound: snd_soc_register_card() failed: -517
[ 6.657738] snd-allo-piano-dac-plus soc:sound: control 2:0:0:Digital Playback Volume:0 is already present
[ 6.657764] pcm512x 1-004d: ASoC: Failed to add Digital Playback Volume: -16
[ 6.659573] snd-allo-piano-dac-plus soc:sound: multicodec <-> 3f203000.i2s mapping ok
[ 6.939589] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 7.588069] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 9.103657] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 12.817416] random: nonblocking pool is initialized
[ 17.634524] FS-Cache: Netfs 'cifs' registered for caching
[ 17.635216] Key type cifs.spnego registered
[ 17.635339] Key type cifs.idmap registered
[ 21.584067] cfg80211: World regulatory domain updated:
[ 21.584094] cfg80211: DFS Master region: unset
[ 21.584104] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 21.584116] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 21.584125] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 21.584135] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 21.584147] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 21.584159] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 21.584169] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 21.584178] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 21.584188] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 22.197395] nf_conntrack version 0.5.0 (14761 buckets, 59044 max)
[ 56.558353] pcm512x 1-004c: No SCLK, using BCLK: -2
[ 56.559906] pcm512x 1-004d: No SCLK, using BCLK: -2
[ 56.564750] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[ 56.567205] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[ 81.754624] cfg80211: Verifying active interfaces after reg change
[54828.555821] pcm512x 1-004c: No SCLK, using BCLK: -2
[54828.556636] pcm512x 1-004d: No SCLK, using BCLK: -2
[54828.560462] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[54828.562868] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[59454.307460] pcm512x 1-004c: No SCLK, using BCLK: -2
[59454.308303] pcm512x 1-004d: No SCLK, using BCLK: -2
[59454.312182] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[59454.314670] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[63996.713057] pcm512x 1-004c: No SCLK, using BCLK: -2
[63996.713825] pcm512x 1-004d: No SCLK, using BCLK: -2
[63996.717363] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[63996.719706] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[64080.632384] pcm512x 1-004c: No SCLK, using BCLK: -2
[64080.633182] pcm512x 1-004d: No SCLK, using BCLK: -2
[64080.636855] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[64080.639275] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[80013.445129] pcm512x 1-004c: No SCLK, using BCLK: -2
[80013.445994] pcm512x 1-004d: No SCLK, using BCLK: -2
[80013.449976] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[80013.452376] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[229871.094915] pcm512x 1-004c: No SCLK, using BCLK: -2
[229871.095763] pcm512x 1-004d: No SCLK, using BCLK: -2
[229871.099564] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[229871.101952] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[314641.595073] pcm512x 1-004c: No SCLK, using BCLK: -2
[314641.595977] pcm512x 1-004d: No SCLK, using BCLK: -2
[314641.599772] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[314641.602310] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[321835.197914] pcm512x 1-004c: No SCLK, using BCLK: -2
[321835.198780] pcm512x 1-004d: No SCLK, using BCLK: -2
[321835.202406] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[321835.204758] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[324111.598317] pcm512x 1-004c: No SCLK, using BCLK: -2
[324111.599084] pcm512x 1-004d: No SCLK, using BCLK: -2
[324111.602650] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[324111.604995] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[350214.897561] pcm512x 1-004c: No SCLK, using BCLK: -2
[350214.898405] pcm512x 1-004d: No SCLK, using BCLK: -2
[350214.902168] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[350214.904675] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[350694.239853] pcm512x 1-004c: No SCLK, using BCLK: -2
[350694.240795] pcm512x 1-004d: No SCLK, using BCLK: -2
[350694.244652] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[350694.247445] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[350856.739756] pcm512x 1-004c: No SCLK, using BCLK: -2
[350856.740621] pcm512x 1-004d: No SCLK, using BCLK: -2
[350856.744532] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[350856.747229] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[350871.143307] pcm512x 1-004c: No SCLK, using BCLK: -2
[350871.144208] pcm512x 1-004d: No SCLK, using BCLK: -2
[350871.148301] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[350871.150865] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[350897.759230] pcm512x 1-004c: No SCLK, using BCLK: -2
[350897.760116] pcm512x 1-004d: No SCLK, using BCLK: -2
[350897.763997] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[350897.766520] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[350918.069340] pcm512x 1-004c: No SCLK, using BCLK: -2
[350918.070199] pcm512x 1-004d: No SCLK, using BCLK: -2
[350918.074317] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[350918.077141] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[350926.370266] pcm512x 1-004c: No SCLK, using BCLK: -2
[350926.371085] pcm512x 1-004d: No SCLK, using BCLK: -2
[350926.374948] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[350926.377501] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[350946.908109] pcm512x 1-004c: No SCLK, using BCLK: -2
[350946.908959] pcm512x 1-004d: No SCLK, using BCLK: -2
[350946.912680] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[350946.915099] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[350951.621040] pcm512x 1-004c: No SCLK, using BCLK: -2
[350951.621864] pcm512x 1-004d: No SCLK, using BCLK: -2
[350951.625735] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[350951.628283] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[350959.523361] pcm512x 1-004c: No SCLK, using BCLK: -2
[350959.524293] pcm512x 1-004d: No SCLK, using BCLK: -2
[350959.528456] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[350959.530899] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[350993.511345] pcm512x 1-004c: No SCLK, using BCLK: -2
[350993.512203] pcm512x 1-004d: No SCLK, using BCLK: -2
[350993.515949] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[350993.518368] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[351346.411775] pcm512x 1-004c: No SCLK, using BCLK: -2
[351346.412597] pcm512x 1-004d: No SCLK, using BCLK: -2
[351346.416445] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[351346.419089] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[352729.013684] pcm512x 1-004c: No SCLK, using BCLK: -2
[352729.014512] pcm512x 1-004d: No SCLK, using BCLK: -2
[352729.018125] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[352729.020479] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[355219.055079] pcm512x 1-004c: No SCLK, using BCLK: -2
[355219.055880] pcm512x 1-004d: No SCLK, using BCLK: -2
[355219.059593] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[355219.062003] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[374804.013419] pcm512x 1-004c: No SCLK, using BCLK: -2
[374804.014250] pcm512x 1-004d: No SCLK, using BCLK: -2
[374804.018032] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[374804.020493] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[427357.593779] pcm512x 1-004c: No SCLK, using BCLK: -2
[427357.594547] pcm512x 1-004d: No SCLK, using BCLK: -2
[427357.598124] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[427357.600471] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[468283.436250] pcm512x 1-004c: No SCLK, using BCLK: -2
[468283.437073] pcm512x 1-004d: No SCLK, using BCLK: -2
[468283.440876] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[468283.443302] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[469745.743444] pcm512x 1-004c: No SCLK, using BCLK: -2
[469745.744227] pcm512x 1-004d: No SCLK, using BCLK: -2
[469745.747856] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[469745.750237] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[471747.949224] pcm512x 1-004c: No SCLK, using BCLK: -2
[471747.950009] pcm512x 1-004d: No SCLK, using BCLK: -2
[471747.953700] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[471747.956104] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[512156.291045] pcm512x 1-004c: No SCLK, using BCLK: -2
[512156.291862] pcm512x 1-004d: No SCLK, using BCLK: -2
[512156.295605] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[512156.298013] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
[519772.705581] pcm512x 1-004c: No SCLK, using BCLK: -2
[519772.706375] pcm512x 1-004d: No SCLK, using BCLK: -2
[519772.710059] pcm512x 1-004c: Setting SCLK as input clock & disabled PLL
[519772.712490] pcm512x 1-004d: Setting SCLK as input clock & disabled PLL
