@[deleted]
On iphone once you swipe left and right to see sources or playlist and turn back to now playing page it not possible to swipe up and down to see the menu bar. You have to close and restart browser to fix it (until you access playlist or sources once again).
Fixed.
If you hold the phone horizontally there are empty pixels above menubar
It may be fixed with other bugs in this update.
While using airplay iphone screen shows just spinning dots
It's fine on 0.3 but failed on 0.4b. I'll look into it.
On local browser detailed information screen shows either no information and spinning dots
or you see information about another artist and spinning dots again. Is there any way to completely disable this layer, as it slows down runeaudio and causes lags in music.
I think it's the screen saver feature that can be disabled by set
ScreenSaver time in Settings to
-1
After update, you can use touch gesture on coverart:
- swipe left/right = previous/next buttons (existing gesture on song info area only)
- tap = play/pause button (existing gesture)
- long-press = stop button
Now only Settings button needs menu bar.
Please update and report.
