More info
journalctl -xe
May 29 14:19:06 classicrunehavana dbus-daemon[257]: [system] Activating via systemd: service name='org.freedesk>
May 29 14:19:06 classicrunehavana dbus-daemon[257]: [system] Activation via systemd failed for unit 'dbus-org.f>
May 29 14:19:06 classicrunehavana sshd[3243]:
pam_systemd(sshd:session): Failed to create session: Unit systemd>
May 29 14:19:12 classicrunehavana kernel: Voltage normalised (0x00000000)
May 29 14:23:09 classicrunehavana kernel:
Under-voltage detected! (0x00050005)
May 29 14:23:13 classicrunehavana kernel: Voltage normalised (0x00000000)
May 29 14:23:15 classicrunehavana sudo[3552]: http : TTY=unknown ; PWD=/srv/http ; USER=root ; COMMAND=/srv>
May 29 14:23:15 classicrunehavana sudo[3552]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 29 14:23:17 classicrunehavana sudo[3552]: pam_unix(sudo:session): session closed for user root
May 29 14:23:17 classicrunehavana sudo[3579]: http : TTY=unknown ; PWD=/srv/http ; USER=root ; COMMAND=/usr>
May 29 14:23:17 classicrunehavana sudo[3579]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 29 14:23:17 classicrunehavana sudo[3579]: pam_unix(sudo:session): session closed for user root
May 29 14:23:27 classicrunehavana sudo[3619]: http : TTY=unknown ; PWD=/srv/http ; USER=root ; COMMAND=./se>
May 29 14:23:27 classicrunehavana sudo[3619]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 29 14:23:27 classicrunehavana systemd[1]: Reloading.
May 29 14:23:28 classicrunehavana systemd[1]: Starting Automatic wireless network connection using netctl profi>
-- Subject: Unit
netctl-auto@wlan0.service has begun start-up
-- Defined-By: systemd
-- Support:
https://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit
netctl-auto@wlan0.service has begun starting up.
May 29 14:23:28 classicrunehavana kernel:
May 29 14:23:28 classicrunehavana netctl-auto[3649]: The interface 'wlan0' is already up
netctl-auto@wlan0.service: Control process exited, code=exited st>
netctl-auto@wlan0.service: Failed with result 'exit-code'.
Failed to start Automatic wireless network connection using netct>
-- Subject: Unit netctl-auto@wlan0.service has failed
-- Support:
-- Unit
netctl-auto@wlan0.service has failed.
-- The result is RESULT.
May 29 14:23:28 classicrunehavana sudo[3619]: pam_unix(sudo:session): session closed for user root
May 29 14:23:34 classicrunehavana kernel: Voltage normalised (0x00000000)
lines 1205-1239/1239 (END)
