cmh714 wrote
any way to do some updating via cli so I dont have to start all over with flashing again?
TIA
*****UPDATE: @[deleted], all good used the above for the update.......so what I saw when running the commands, is that for some reason many things seem to be talking a lot longer than usual.....therefore, you need to be patient when running the update.
PS: I did not run into the locales issue mentioned. HTH
I am still missing the gitpull button on the Dev page....
The pakages,
ImageMagick and depends, are about 12MB to download and install. ImageMagick alone is just a few MBs but some packages in the system need updates to current versions. It'll take a while, a minute or two. RuneUI Enhancement itself takes less than 10 seconds.
Yes, be patient. Once installed, RuneUIe update will be in seconds again.
The gitpull button - It's mostly if not all about RuneUI. You should uninstall RuneUIe before doing the gitpull then reinstall.
Tips: Reset RuneUI and uninstall all addons to default
Most of the times there's no need to reflash. Try this:
RuneUI Reset in Addons page
- SSH command -
ui_reset.sh
