Please explain the "just change stations without doing it twice" thing.
If I select a station from the webradio list and use replace/play to add it to the playlist, info will not scroll.
If I go back to the webradio list and select the same station again using replace/play, the info on the playback page will scroll.
If I tilt the tablet 90 deg, the scrolling stops until I select the station again.
I think these problems started after the "tap once to add/play" feature. If I use tap once to switch stations a few times, the playlist becomes a mess, and the metadata info is replaced with the station name, so I do not use this feature.
