vincenzomaletta wroteHello,
first of all, compliments for your work and your detailed explanations.
I'd like to know why did you use adjustable version of the LDO, and not the fixed one for 3.3 and 1.8 V.
I also see that you put a small capacitor in parallel to each diode. I've never seen such a configuration; what's the scope of those capacitors ?
LBNL: using 4 filtering capacitors instead a single bigger one, has any benefit on the output ripple ?
Thank you for your answers.
Vincenzo
Sorry for my late reply, I'm quite busy at the moment.
Thank you for your compliments.
I use adjustable ones, because I couldn't get the fixed ones very easy. I've finetuned the voltages and everythins is stable as a rock now. The 1V8 and 3V3 get really hot (logical), the 5V for the Raspi too (also logical). They all got a nice heatsink now and temperature is acceptable now.
The parallel capacitors take care of any HF noise. I used shottky diodes, the capacitors are just to be sure. I've good experience with this design which I used before. Be sure to use ceramic capacitors.
Four filtering capacitors in parallel gives a better ESR result than a bigger single one.
Richard.
