Vinboy wroteVinboy wrote Hello
I have uncomment only one line for iqaudio-dacplus (it should activate any PCM 51xx), and after reboot or switch it off from supply has appeared iqaudio in the MPD menu (but it seems that it didnt work for the first attempt), when I will be home send you exact config.txt extraction, also I set sound signature on ACX or Um3..., remaining sometimes muted audio output.
But also you can try or you should try first moode player if your DAC works correctly...
PS: i would like also compare Moode vs Runeaudio software if it has any impact on the final SQ but as I understand Kali Reclocker makes the big improvement of SQ so changing of software or sound signature in Rune should not have any audible impact on SQ maybe sligtly....this is my result when i switched from Mambo LS (ESS9023) onto Kali DAC (PCM5211), my impressions are above in old remarks...Kali is more open, more huge 3D stereo ....briefly said
Excuse me but I have not understood the phrase " also I set sound signature on ACX or Um3..., remaining sometimes muted audio output"...
Anyway, I would definitely use runeaudio (and I would avoid moode, I don't like it)!
Sorry ... now I understand what you mean.
I always's used sound signature: "Arch Linux default" or "RuneAudio".
I await your config.txt!
Thank you!
Hi, ok maybe i wrote it very briefly and badly, switching between sound signatures in RuneOS kernel settings caused sometimes sound disappearance with using Piano DAC, ACX and Um3ggh1U works for me (but maybe will test remaining profiles to find why or by what it is caused..but differences are minimally) anyway my config below after this IQaudIODAC is visible in MPD confuguration:
# Uncomment one of these lines to enable an audio interface
#dtoverlay=hifiberry-dacplus
#dtoverlay=hifiberry-digi
#dtoverlay=hifiberry-amp
#dtoverlay=iqaudio-dac
dtoverlay=iqaudio-dacplus
PS: I agree RUNE is better than Moode for its visual clarity....
