I use smb.
Raspbian mpd.conf:
# An example configuration file for MPD
# See the mpd.conf man page for a more detailed description of each parameter.
# Files and directories #######################################################
# This setting controls the top directory which MPD will search to discover the
# available audio files and add them to the daemon's online database. This
# setting defaults to the XDG directory, otherwise the music directory will be
# be disabled and audio files will only be accepted over ipc socket (using
# file:// protocol) or streaming files over an accepted protocol.
music_directory "/mnt/WDMusic"
# This setting sets the MPD internal playlist directory. The purpose of this
# directory is storage for playlists created by MPD. The server will use
# playlist files not created by the server but only if they are in the MPD
# format. This setting defaults to playlist saving being disabled.
# This setting sets the location of the MPD database. This file is used to
# load the database at server start up and store the database while the
# server is not up. This setting defaults to disabled which will allow
# MPD to accept files over ipc socket (using file:// protocol) or streaming
# files over an accepted protocol.
db_file "/var/lib/mpd/tag_cache"
# These settings are the locations for the daemon log files for the daemon.
# These logs are great for troubleshooting, depending on your log_level
# settings.
# The special value "syslog" makes MPD use the local syslog daemon. This
# setting defaults to logging to syslog, otherwise logging is disabled.
log_level "verbose"
log_file "/var/log/mpd/mpd.log"
# This setting sets the location of the file which stores the process ID
# for use of mpd --kill and some init scripts. This setting is disabled by
# default and the pid file will not be stored.
# This setting sets the location of the file which contains information about
# most variables to get MPD back into the same general shape it was in before
# it was brought down. This setting is disabled by default and the server
# state will be reset on server start up.
state_file "/var/lib/mpd/state"
# The location of the sticker database. This is a database which
# manages dynamic information attached to songs.
# General music daemon options ################################################
# This setting specifies the user that MPD will run as. MPD should never run as
# root and you may use this setting to make MPD change its user ID after
# initialization. This setting is disabled by default and MPD is run as the
# current user.
# This setting specifies the group that MPD will run as. If not specified
# primary group of user specified with "user" setting will be used (if set).
# This is useful if MPD needs to be a member of group such as "audio" to
# have permission to use sound card.
#group "nogroup"
# This setting sets the address for the daemon to listen on. Careful attention
# should be paid if this is assigned to anything other then the default, any.
# This setting can deny access to control of the daemon. Choose any if you want
# to have mpd listen on every address
# For network
# And for Unix Socket
#bind_to_address "/var/run/mpd/socket"
# This setting is the TCP port that is desired for the daemon to get assigned
# to.
#port "6600"
# This setting controls the type of information which is logged. Available
# setting arguments are "default", "secure" or "verbose". The "verbose" setting
# argument is recommended for troubleshooting, though can quickly stretch
# available resources on limited hardware storage.
#log_level "default"
# If you have a problem with your MP3s ending abruptly it is recommended that
# you set this argument to "no" to attempt to fix the problem. If this solves
# the problem, it is highly recommended to fix the MP3 files with vbrfix
# (available as vbrfix in the debian archive), at which
# point gapless MP3 playback can be enabled.
#gapless_mp3_playback "yes"
# This setting enables MPD to create playlists in a format usable by other
# music players.
#save_absolute_paths_in_playlists "no"
# This setting defines a list of tag types that will be extracted during the
# audio file discovery process. Optionally, 'comment' can be added to this
# list.
#metadata_to_use "artist,album,title,track,name,genre,date,composer,performer,disc"
# This setting enables automatic update of MPD's database when files in
# music_directory are changed.
#auto_update "yes"
# Limit the depth of the directories being watched, 0 means only watch
# the music directory itself. There is no limit by default.
#auto_update_depth "3"
# Symbolic link behavior ######################################################
# If this setting is set to "yes", MPD will discover audio files by following
# symbolic links outside of the configured music_directory.
#follow_outside_symlinks "yes"
# symbolic links inside of the configured music_directory.
#follow_inside_symlinks "yes"
# Zeroconf / Avahi Service Discovery ##########################################
# If this setting is set to "yes", service information will be published with
# Zeroconf / Avahi.
#zeroconf_enabled "yes"
# The argument to this setting will be the Zeroconf / Avahi unique name for
# this MPD server on the network.
#zeroconf_name "Music Player"
# Permissions #################################################################
# If this setting is set, MPD will require password authorization. The password
# can setting can be specified multiple times for different password profiles.
#password "password@read,add,control,admin"
# This setting specifies the permissions a user has who has not yet logged in.
#default_permissions "read,add,control,admin"
# Input #######################################################################
# proxy "proxy.isp.com:8080"
# proxy_user "user"
# proxy_password "password"
# Audio Output ################################################################
# MPD supports various audio output types, as well as playing through multiple
# audio outputs at the same time, through multiple audio_output settings
# blocks. Setting this block is optional, though the server will only attempt
# autodetection for one sound card.
# See <http://mpd.wikia.com/wiki/Configuration#Audio_Outputs> for examples of
# other audio outputs.
# An example of an ALSA output:
name "My ALSA Device"
device "hw:0,0" # optional
# An example of an OSS output:
#audio_output {
# type "oss"
# name "My OSS Device"
# device "/dev/dsp" # optional
# format "44100:16:2" # optional
# mixer_device "/dev/mixer" # optional
# mixer_control "PCM" # optional
# An example of a shout output (for streaming to Icecast):
#audio_output {
# type "shout"
# encoding "ogg" # optional
# name "My Shout Stream"
# host "localhost"
# port "8000"
# mount "/mpd.ogg"
# password "hackme"
# quality "5.0"
# bitrate "128"
# format "44100:16:1"
# protocol "icecast2" # optional
# user "source" # optional
# description "My Stream Description" # optional
# genre "jazz" # optional
# public "no" # optional
# timeout "2" # optional
# An example of a recorder output:
#audio_output {
# type "recorder"
# name "My recorder"
# encoder "vorbis" # optional, vorbis or lame
# path "/var/lib/mpd/recorder/mpd.ogg"
## quality "5.0" # do not define if bitrate is defined
# bitrate "128" # do not define if quality is defined
# An example of a httpd output (built-in HTTP streaming server):
#audio_output {
# type "httpd"
# name "My HTTP Stream"
# port "8000"
# An example of a pulseaudio output (streaming to a remote pulseaudio server)
#audio_output {
# type "pulse"
# name "My Pulse Output"
# server "remote_server" # optional
# sink "remote_server_sink" # optional
## Example "pipe" output:
#audio_output {
# type "pipe"
# name "my pipe"
# command "aplay -f cd 2>/dev/null"
## Or if you're want to use AudioCompress
# command "AudioCompress -m | aplay -f cd 2>/dev/null"
## Or to send raw PCM stream through PCM:
# command "nc example.org 8765"
## An example of a null output (for no audio output):
#audio_output {
# type "null"
# name "My Null Output"
# This setting will change all decoded audio to be converted to the specified
# format before being passed to the audio outputs. By default, this setting is
# disabled.
#audio_output_format "44100:16:2"
# If MPD has been compiled with libsamplerate support, this setting specifies
# the sample rate converter to use. Possible values can be found in the
# mpd.conf man page or the libsamplerate documentation. By default, this is
# setting is disabled.
#samplerate_converter "Fastest Sinc Interpolator"
# Volume control mixer ########################################################
# These are the global volume control settings. By default, this setting will
# be detected to the available audio output device, with preference going to
# hardware mixing. Hardware and software mixers for individual audio_output
# sections cannot yet be mixed.
# An example for controlling an ALSA, OSS or Pulseaudio mixer; If this
# setting is used other sound applications will be affected by the volume
# being controlled by MPD.
#mixer_type "hardware"
# An example for controlling all mixers through software. This will control
# all controls, even if the mixer is not supported by the device and will not
# affect any other sound producing applications.
mixer_type "software"
# This example will not allow MPD to touch the mixer at all and will disable
# all volume controls.
#mixer_type "disabled"
# Normalization automatic volume adjustments ##################################
# This setting specifies the type of ReplayGain to use. This setting can have
# the argument "album" or "track". See <http://www.replaygain.org> for more
# details. This setting is disabled by default.
#replaygain "album"
# This setting sets the pre-amp used for files that have ReplayGain tags. By
# default this setting is disabled.
#replaygain_preamp "0"
# This setting enables on-the-fly normalization volume adjustment. This will
# result in the volume of all playing audio to be adjusted so the output has
# equal "loudness". This setting is disabled by default.
#volume_normalization "no"
# MPD Internal Buffering ######################################################
# This setting adjusts the size of internal decoded audio buffering. Changing
# this may have undesired effects. Don't change this if you don't know what you
# are doing.
audio_buffer_size "8192"
# This setting controls the percentage of the buffer which is filled before
# beginning to play. Increasing this reduces the chance of audio file skipping,
# at the cost of increased time prior to audio playback.
buffer_before_play "20%"
# Resource Limitations ########################################################
# These settings are various limitations to prevent MPD from using too many
# resources. Generally, these settings should be minimized to prevent security
# risks, depending on the operating resources.
#connection_timeout "60"
#max_connections "10"
#max_playlist_length "16384"
#max_command_list_size "2048"
#max_output_buffer_size "8192"
# Character Encoding ##########################################################
# If file or directory names do not display correctly for your locale then you
# may need to modify this setting. After modification of this setting mpd
# --create-db must be run to change the database.
# This setting controls the encoding that ID3v1 tags should be converted from.
# SIDPlay decoder #############################################################
# songlength_database:
# Location of your songlengths file, as distributed with the HVSC.
# The sidplay plugin checks this for matching MD5 fingerprints.
# See http://www.c64.org/HVSC/DOCUMENTS/Songlengths.faq
# default_songlength:
# This is the default playing time in seconds for songs not in the
# songlength database, or in case you're not using a database.
# A value of 0 means play indefinitely.
# filter:
# Turns the SID filter emulation on or off.
#decoder {
# plugin "sidplay"
# songlength_database "/media/C64Music/DOCUMENTS/Songlengths.txt"
# default_songlength "120"
# filter "true"
Raspbian cifs mount:
//WDMusic/Music on /mnt/WDMusic type cifs (rw,relatime,vers=1.0,cache=strict,username=admin,domain=WDMUSIC,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.1.163,file_mode=0777,dir_mode=0777,nounix,serverino,rsize=61440,wsize=65536,actimeo=1)
RuneAudio mpd.conf:
log_level "verbose"
log_file "/tmp/mpd.log"
zeroconf_name "runeaudio"
auto_update "no"
replaygain "off"
name "snd_rpi_hifiberry_digi"
device "hw:1,0"
RuneAudio cifs mount:
//WDMusic/Music on /mnt/MPD/NAS/WDMusic type cifs (ro,relatime,vers=1.0,sec=ntlm,cache=none,uid=1000,forceuid,gid=92,forcegid,addr=192.168.1.163,file_mode=0755,dir_mode=0755,nounix,mapposix,rsize=16384,wsize=17408,actimeo=1)
test while hard file operations on WD:
RuneAudio with underruns:
Aug 31 19:57 : alsa_output: opened hw:1,0 type=HW
Aug 31 19:57 : alsa_output: format=S32_LE (Signed 32 bit Little Endian)
Aug 31 19:57 : alsa_output: buffer: size=8..65536 time=41..341334
Aug 31 19:57 : alsa_output: period: size=4..32768 time=20..170667
Aug 31 19:57 : alsa_output: default period_time = buffer_time/4 = 341333/4 = 85333
Aug 31 19:57 : alsa_output: buffer_size=65536 period_size=16384
Aug 31 19:57 : output: opened plugin=alsa name="snd_rpi_hifiberry_digi" audio_format=192000:32:2
Aug 31 19:58 : alsa_output: Underrun on ALSA device "hw:1,0"
Aug 31 20:02 : alsa_output: Underrun on ALSA device "hw:1,0"
Aug 31 20:08 : alsa_output: Underrun on ALSA device "hw:1,0"
Aug 31 20:09 : alsa_output: Underrun on ALSA device "hw:1,0"
Aug 31 20:11 : alsa_output: Underrun on ALSA device "hw:1,0"
Aug 31 20:14 : alsa_output: Underrun on ALSA device "hw:1,0"
Raspbian ... only 1 underrun... huh (at the same time):
Aug 31 19:52 : alsa: buffer: size=8..65536 time=41..341334
Aug 31 19:52 : alsa: period: size=4..32768 time=20..170667
Aug 31 19:52 : alsa: default period_time = buffer_time/4 = 341333/4 = 85333
Aug 31 19:52 : alsa: buffer_size=65536 period_size=16384
Aug 31 19:52 : output: opened plugin=alsa name="My ALSA Device" audio_format=192000:24:2
Aug 31 20:08 : alsa: Underrun on ALSA device "hw:0,0"
