Hi Boydwilluk,
i tried booth URL and booth work like they should on my RP2 with a Hifiberry DAC+.
OK, i read your older posts again.
The problem is that you are using a Hifiberry AMP+.
This is the first stream:
access: RW_INTERLEAVED
format: S24_LE
subformat: STD
channels: 2
rate: 22050 (352800/16)
period_size: 3675
buffer_size: 11025
and here the second:
format: S16_LE
subformat: STD
channels: 2
rate: 44100 (352800/8)
period_size: 4410
buffer_size: 22050
As the Amp supports only 44.1 and 48kHz, 22kHz won't play natively.
You need to convert these to 44.1kHz.
This can be done by modifying mpd.conf.
Please read
this.
Change 96000 to 44100 and replace "snd_rpi_hifiberry_digi" with "snd_rpi_hifiberry_amp"
