irishwill2008 It worked for me perfectly! Only thing is i cannot access the loca SSH terminal? Before this, i use to be able to press CTRL & Shift + W to exit midori which then brang you to the login screen, from there you can login as root and type commands etc but now i just get a black screen as if this terminal is disabled? Is there something to re-enable this with the splash screen still in function? Thanks!
hondagx35 Hi irishwill2008, Is there something to re-enable this with the splash screen still in function? After exiting midori with CTRL & Shift + W you can try to switch console with ALT + => (right arrow key) Frank
