Hello, I just fired up my Raspberry Pi 2 with HiFiBerry Digi+ , extremely pleased and all is working well. I have a self powered USB drive with 28,000 tracks now indexed. My problem is that if I search for say "Endless River" while in the Album search db, I get a list of all songs on that album and another songs with those search terms. Is it possible to get a result which is just the albums? This would be so much easier when adding the entire album to a playlist. and Secondly, when searching MPD ARTIST, the last name of an artist gets me a list of results all tagged "undefined" .
Linux version 3.18.7-3-ARCH (builduser@leming) (gcc version 4.9.2 20141224 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Feb 13 06:23:21 MST 2015
system time: Tue Mar 22 13:48:00 CET 2016
system load: 0.02 0.09 0.12 2/118 1609
HW platform: RaspberryPi2 (08)
playerID: 08b26fff2ac4ddac6fee7fbbc1890504ae
sh: procinfo: command not found
systemd-+-2*[agetty]
|-avahi-daemon---avahi-daemon
|-dbus-daemon
|-devmon---udevil
|-dhcpcd
|-ifplugd
|-mpd-+-{decoder:flac}
| |-{io}
| |-{output:snd_rpi_}
| `-{player}
|-nginx---nginx
|-nmbd
|-ntpd
|-php-fpm---3*[php-fpm]
|-rune_PL_wrk
|-rune_SY_wrk---sh---debug_collector---sh---pstree
|-shairport---{shairport}
|-smbd---smbd
|-sshd
|-systemd-network
|-systemd-resolve
|-systemd-udevd
|-wpa_actiond
`-wpa_supplicant
Advanced Linux Sound Architecture Driver Version k3.18.7-3-ARCH.
0 [ALSA ]: bcm2835 - bcm2835 ALSA
bcm2835 ALSA
1 [sndrpihifiberry]: snd_rpi_hifiber - snd_rpi_hifiberry_digi
PLAYBACK devices: (aplay -l)
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 1: sndrpihifiberry [snd_rpi_hifiberry_digi], device 0: HifiBerry Digi HiFi wm8804-spdif-0 []
Subdevices: 0/1
PCM devices: (aplay -L)
null
default:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
sysdefault:CARD=ALSA
default:CARD=sndrpihifiberry
snd_rpi_hifiberry_digi,
sysdefault:CARD=sndrpihifiberry
card 0:
Simple mixer control 'PCM',0
card 1:
Simple mixer control 'AIF',0
Simple mixer control 'Input Source',0
Simple mixer control 'TX',0
card 0:
numid=3,iface=MIXER,name='PCM Playback Route'
numid=1,iface=MIXER,name='PCM Playback Volume'
numid=5,iface=PCM,name='IEC958 Playback Con Mask'
numid=4,iface=PCM,name='IEC958 Playback Default'
card 1:
numid=3,iface=MIXER,name='AIF Playback Switch'
numid=1,iface=MIXER,name='Input Source'
numid=2,iface=MIXER,name='TX Playback Switch'
Output 1 (bcm2835 ALSA_1) is disabled
Output 2 (snd_rpi_hifiberry_digi) is enabled
Output 3 (bcm2835 ALSA_2) is disabled
zeroconf_name "RuneAudio"
auto_update "yes"
audio_buffer_size "2048"
buffer_before_play "10%"
mixer_type "disabled"
name "bcm2835 ALSA_1"
dsd_usb "yes"
name "snd_rpi_hifiberry_digi"
device "hw:1,0"
dsd_usb "yes"
name "bcm2835 ALSA_2"
dsd_usb "yes"
hardware platform: RaspberryPi2
current orionprofile: ACX
kernel scheduler for mmcblk0: [noop] deadline cfq bfq
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 18000000
/proc/sys/kernel/sched_rr_timeslice_ms: 10
total 8.0K
drwxr-xr-x 2 root root 4.0K Mar 21 22:28 .
drwxr-xr-x 6 root root 4.0K Feb 23 2015 ..
lrwxrwxrwx 1 root root 38 Feb 14 2015 dhcpcd.service -> /usr/lib/systemd/system/dhcpcd.service
lrwxrwxrwx 1 root root 44 Mar 21 22:28 netctl-auto@wlan0.service -> /usr/lib/systemd/system/netctl-auto@.service
lrwxrwxrwx 1 root root 47 Mar 21 22:25 netctl-ifplugd@eth0.service -> /usr/lib/systemd/system/netctl-ifplugd@.service
lrwxrwxrwx 1 root root 36 Feb 15 2015 ntpd.service -> /usr/lib/systemd/system/ntpd.service
lrwxrwxrwx 1 root root 51 Dec 18 2014 remote-fs.target -> ../../../../usr/lib/systemd/system/remote-fs.target
lrwxrwxrwx 1 root root 48 Feb 8 2015 systemd-networkd.service -> /usr/lib/systemd/system/systemd-networkd.service
lrwxrwxrwx 1 root root 48 Feb 8 2015 systemd-resolved.service -> /usr/lib/systemd/system/systemd-resolved.service
