johnbanks wrotePeteB ...
What is the gizmo that's showing 5.11 V and 0.50 A in the photo?
It is a small USB in-line multimeter, about $10~12 on amazon.com. Basically, a dongle that measures current, voltage, and calculates power. You put it inline with the main power, or just one of the USB dongles or the disk drive. It has one power-only connector, and one power+data passthrough connector.
The one that worked best for my purposes is this one:
DROK USB 2.0 Digital Multimeter, Ammeter Voltmeter Capacitance & Watt Meter
http://www.amazon.com/DROK-Multimeter-Voltmeter-Capacitance-Charging/dp/B00J3JSEG6?ie=UTF8&refRID=KN0Q7GQKWWA86MTSBX68
There are others, you may find one you like better. I use this to monitor current during use, to see if a dongle is using too much power, etc.
To measure the initial startup current or voltage accurately, you need a real multimeter, and more wires, and some test leads with small ends... unfortunately I cannot leave all that hooked up for days. You can get some idea of the startup current with the dongle, but not as accurate.
You can clearly see that a new-ish 2.5" disk drive, single or dual platter, does not exceed the 2A on a Pi 2, even with other dongles plugged in. During play, the current is only around 0.5A.
With an older higher power drive, like a Western Digital Black (I tested a WD7500BPKX), a 2A supply will struggle during start. With a stronger supply (mine came from Gizmo Junkies but there are others), even those will work, but I would not recommend it, because the Pi may detect the excess current. So, unfortunately, not every old 2.5" drive in my parts bin will work.
A WD5000LPVX seems ideal, $40/500GB, if you don't mind the extra $10 for the SATA-to-USB adapter.
