hondagx35 wroteBTW: Did someone test the new "global random" feature (aka ashuffle)?
With all respect, some of us may not know how it is supposed to work...
I tried it set to 1 track, and it seemed to add a track like I expected, then go to the top, and repeat, but not like I expected. Is this intended to be used in combination with random in the play screen or is it mutually exclusive with normal random play?
When random is NOT enabled in the play screen, then it just adds tracks each time when the queue finishes.... in any case, it looks like I did not understand how it works.
I also encountered an old problem again when I was using this option. A couple times when a track finished playing, instead of going on to another track, the output went silent, and the playback timer continued to count past the duration of the track, while the completed track name and album art stayed on the screen.
I am not able add to the queue from the Artist screen, or from the Genres screen. Not if I want to add all of a given artist to the queue. Add does not work, add and play neither. Add, play and replace clears the queue but does not play.
I think I also do not understand how "Save as bookmark" works. How can I take the bookmarks out again once they are in the Library screen?
Regards,
Pete
