alvaron wroteHi Frank and dunghnguyen I was away and just returned to my shack.
I am using hifiberry dac in my config.sys wit i2sparameters on
the DAC is the Audiophonics ES9018Mk2 board....connected with just 4 i2s lines to the Pi3
the word lenght is 24 as instructed by you Frank !!!
Regards,
Alvaro
I tried with my case for board ES9018K2M as following photos
I edit the
/etc/mod.conf as Frank's instruction to add in
"*:24:*" then restart MPD by command
systemctl restart mpd that I have seen this
Click on MANUAL EDIT I have this.
Continue doing this but it failed that the MPD appeared as above photo
hondagx35 wrote
- edit the file "/srv/http/db/redis_acards_details"
Find your DAC and add "card_option":"format\t\"*:24:*\""
Here an example for the snd_rpi_hifiberry_dac
$redis->hSet('acards_details', 'snd_rpi_hifiberry_dac', '{"sysname":"snd_rpi_hifiberry_dac","extlabel":"HiFiBerry DAC (I²S)","hwplatformid":"01","type":"i2s"}');
to
$redis->hSet('acards_details', 'snd_rpi_hifiberry_dac', '{"sysname":"snd_rpi_hifiberry_dac","extlabel":"HiFiBerry DAC (I²S)","card_option":"format\t\"*:24:*\"","hwplatformid":"01","type":"i2s"}');
edit: changed it to the correct DAC
- execute these commands:
redis-cli del acards
php /srv/http/db/redis_acards_details
- reboot
This is the /etc/mpd.conf of mine
log_level "default"
zeroconf_name "runeaudio"
auto_update "no"
audio_buffer_size "2048"
buffer_before_play "20%"
mixer_type "disabled"
replaygain "off"
name "snd_rpi_hifiberry_dac"
device "hw:1,0"
format "*:24:*"
name "bcm2835 ALSA_1"
name "bcm2835 ALSA_2"
So do those above steps that you have been doing? Thanks.
