The screenshots are out of order
Also, I can't post the debug info, it's too long
Linux version 3.18.7-3-ARCH (builduser@leming) (gcc version 4.9.2 20141224 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Feb 13 06:23:21 MST 2015
system time: Thu Jan 1 01:00:24 CET 1970
system load: 0.90 0.21 0.07 1/125 730
HW platform: RaspberryPi2 (08)
playerID: 08b26fff2ac4ddac6fee7fbbc1890504ae
sh: procinfo: command not found
systemd-+-2*[agetty]
|-avahi-daemon---avahi-daemon
|-dbus-daemon
|-devmon---udevil
|-dhcpcd
|-ifplugd
|-mpd-+-{decoder}
| |-{io}
| |-{output:bcm2835 }
| `-{player}
|-nginx---nginx
|-nmbd
|-ntpd---{ntpd}
|-php-fpm---3*[php-fpm]
|-rune_PL_wrk
|-rune_SY_wrk
|-shairport---{shairport}
|-smbd---smbd
|-sshd
|-systemd-network
|-systemd-resolve
|-systemd-udevd
|-upmpdcli
|-wpa_actiond
`-wpa_supplicant
Advanced Linux Sound Architecture Driver Version k3.18.7-3-ARCH.
0 [ALSA ]: bcm2835 - bcm2835 ALSA
bcm2835 ALSA
PLAYBACK devices: (aplay -l)
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Subdevices: 1/1
PCM devices: (aplay -L)
null
default:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
sysdefault:CARD=ALSA
card 0:
Simple mixer control 'PCM',0
card 0:
numid=3,iface=MIXER,name='PCM Playback Route'
numid=1,iface=MIXER,name='PCM Playback Volume'
numid=5,iface=PCM,name='IEC958 Playback Con Mask'
numid=4,iface=PCM,name='IEC958 Playback Default'
Output 1 (bcm2835 ALSA_1) is disabled
Output 2 (bcm2835 ALSA_2) is enabled
zeroconf_name "RuneAudio"
auto_update "no"
audio_buffer_size "2048"
buffer_before_play "10%"
mixer_type "disabled"
name "bcm2835 ALSA_1"
name "bcm2835 ALSA_2"
hardware platform: RaspberryPi2
kernel scheduler for mmcblk0: [noop] deadline cfq bfq
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 18000000
/proc/sys/kernel/sched_rr_timeslice_ms: 10
total 8.0K
drwxr-xr-x 2 root root 4.0K Feb 12 2016 .
drwxr-xr-x 6 root root 4.0K Feb 11 2016 ..
lrwxrwxrwx 1 root root 38 Feb 14 2015 dhcpcd.service -> /usr/lib/systemd/system/dhcpcd.service
lrwxrwxrwx 1 root root 44 Feb 12 2016 netctl-auto@wlan0.service -> /usr/lib/systemd/system/netctl-auto@.service
lrwxrwxrwx 1 root root 47 Feb 11 2016 netctl-ifplugd@eth0.service -> /usr/lib/systemd/system/netctl-ifplugd@.service
lrwxrwxrwx 1 root root 40 Feb 11 2016 netctl@ruby2.service -> /etc/systemd/system/netctl@ruby2.service
lrwxrwxrwx 1 root root 36 Feb 15 2015 ntpd.service -> /usr/lib/systemd/system/ntpd.service
lrwxrwxrwx 1 root root 51 Dec 18 2014 remote-fs.target -> ../../../../usr/lib/systemd/system/remote-fs.target
lrwxrwxrwx 1 root root 48 Feb 8 2015 systemd-networkd.service -> /usr/lib/systemd/system/systemd-networkd.service
lrwxrwxrwx 1 root root 48 Feb 8 2015 systemd-resolved.service -> /usr/lib/systemd/system/systemd-resolved.service
rootfs / rootfs rw 0 0
devtmpfs /dev devtmpfs rw,relatime,size=375548k,nr_inodes=93887,mode=755 0 0
cgroup /sys/fs/cgroup/bfqio cgroup rw,nosuid,nodev,noexec,relatime,bfqio 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=27,pgrp=1,timeout=300,minproto=5,maxproto=5,direct 0 0
tmpfs /tmp tmpfs rw 0 0
/dev/sda1 /mnt/MPD/USB/MUSIC vfat ro,nosuid,nodev,noexec,noatime,uid=1000,gid=92,fmask=0022,dmask=0022,codepage=437,iocharset=utf8,shortname=mixed,errors=remount-ro 0 0
/dev/root 1.7G 1.4G 256M 85% /
devtmpfs 367M 0 367M 0% /dev
tmpfs 371M 0 371M 0% /dev/shm
tmpfs 371M 324K 371M 1% /run
tmpfs 371M 0 371M 0% /sys/fs/cgroup
tmpfs 371M 0 371M 0% /tmp
logs 5.0M 16K 5.0M 1% /var/log
rune-logs 5.0M 108K 4.9M 3% /var/log/runeaudio
/dev/mmcblk0p1 100M 13M 88M 13% /boot
/dev/sda1 3.8G 172M 3.6G 5% /mnt/MPD/USB/MUSIC
###### Loaded kernel modules ######
Module Size Used by
nls_utf8 1296 1
arc4 1703 2
rt2800usb 17721 0
rt2800lib 77178 1 rt2800usb
rt2x00usb 11369 1 rt2800usb
rt2x00lib 43985 3 rt2x00usb,rt2800lib,rt2800usb
mac80211 515096 3 rt2x00lib,rt2x00usb,rt2800lib
cfg80211 455144 2 mac80211,rt2x00lib
crc_ccitt 1576 1 rt2800lib
leds_gpio 3530 0
led_class 4035 2 leds_gpio,rt2x00lib
uio_pdrv_genirq 3281 0
uio 8710 1 uio_pdrv_genirq
sch_fq_codel 7252 8
snd_bcm2835 20881 0
snd_pcm 86661 1 snd_bcm2835
snd_timer 19608 1 snd_pcm
snd 60836 3 snd_bcm2835,snd_timer,snd_pcm
bcm2708_rng 1143 0
rng_core 5666 1 bcm2708_rng
ipv6 342650 0
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 348/smbd
tcp 0 0 0.0.0.0:6600 0.0.0.0:* LISTEN 391/mpd
tcp 0 0 0.0.0.0:5002 0.0.0.0:* LISTEN 406/shairport
tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 348/smbd
tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 263/redis-server 12
tcp 0 0 0.0.0.0:5355 0.0.0.0:* LISTEN 234/systemd-resolve
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 272/nginx: master p
tcp 0 0 0.0.0.0:81 0.0.0.0:* LISTEN 272/nginx: master p
tcp 0 0 0.0.0.0:82 0.0.0.0:* LISTEN 272/nginx: master p
tcp 0 0 0.0.0.0:83 0.0.0.0:* LISTEN 272/nginx: master p
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 258/sshd
udp 0 0 0.0.0.0:68 0.0.0.0:* 213/dhcpcd
udp 0 0 127.0.0.1:123 0.0.0.0:* 266/ntpd
udp 0 0 0.0.0.0:123 0.0.0.0:* 266/ntpd
udp 0 0 0.0.0.0:137 0.0.0.0:* 345/nmbd
udp 0 0 0.0.0.0:138 0.0.0.0:* 345/nmbd
udp 0 0 0.0.0.0:59100 0.0.0.0:* 197/avahi-daemon: r
udp 0 0 0.0.0.0:5353 0.0.0.0:* 197/avahi-daemon: r
udp 0 0 0.0.0.0:5355 0.0.0.0:* 234/systemd-resolve
unix 2 [ ACC ] STREAM LISTENING 11014 213/dhcpcd /run/dhcpcd.sock
unix 2 [ ACC ] STREAM LISTENING 11016 213/dhcpcd /run/dhcpcd.unpriv.sock
unix 2 [ ACC ] SEQPACKET LISTENING 38 1/init /run/udev/control
unix 2 [ ACC ] STREAM LISTENING 2622 263/redis-server 12 /tmp/redis.sock
unix 2 [ ACC ] STREAM LISTENING 11639 453/php-fpm: master /var/run/php-display.sock
unix 2 [ ACC ] STREAM LISTENING 11642 453/php-fpm: master /var/run/php-db.sock
unix 2 [ ACC ] STREAM LISTENING 11645 453/php-fpm: master /var/run/php-command.sock
unix 2 [ ACC ] STREAM LISTENING 2440 1/init /var/run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 2443 1/init /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 2446 1/init /run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 1975 391/mpd /run/mpd.sock
unix 2 [ ACC ] STREAM LISTENING 8935 1/init /run/systemd/private
###### Network established sockets (netstat -np) ######
Active Internet connections (w/o servers)
tcp 0 0 127.0.0.1:45851 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45901 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45735 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:39116 127.0.0.1:6600 ESTABLISHED 394/upmpdcli
tcp 0 0 127.0.0.1:45937 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45806 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46036 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46181 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45765 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45994 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45992 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45969 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45810 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45882 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45724 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45974 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45770 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45784 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46059 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45816 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46044 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46131 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46140 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45897 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:49496 TIME_WAIT -
tcp 0 0 127.0.0.1:45903 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45774 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46064 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46053 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45775 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45933 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45795 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45738 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45972 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46048 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46128 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45954 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46010 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46046 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46104 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46123 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45760 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45710 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46120 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45952 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45717 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46096 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45811 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45885 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45894 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45877 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45991 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:49485 TIME_WAIT -
tcp 0 0 127.0.0.1:45905 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45709 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46041 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45780 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45967 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46034 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45843 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46113 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45932 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46054 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46023 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45957 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45979 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45941 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46040 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46012 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45778 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:6600 127.0.0.1:39116 ESTABLISHED 391/mpd
tcp 0 0 127.0.0.1:45964 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45819 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46177 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45802 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45839 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46021 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45793 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45955 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45899 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46019 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45986 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46152 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45763 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45956 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46163 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46083 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45713 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45743 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45971 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45752 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45868 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46049 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46122 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45984 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46061 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46158 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46145 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45739 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46178 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45824 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46183 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45744 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46098 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45818 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45929 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45944 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45800 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46105 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46055 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46125 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46146 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45915 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46065 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:49522 TIME_WAIT -
tcp 0 0 127.0.0.1:45951 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46182 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45750 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45721 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46082 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45930 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45820 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45998 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45758 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46132 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46051 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45989 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45900 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45999 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45926 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45935 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45936 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46015 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46029 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45767 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45711 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46022 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46068 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46126 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45803 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45886 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45958 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46020 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46077 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46159 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45753 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45725 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45827 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46018 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45716 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46017 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46114 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45939 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:49725 TIME_WAIT -
tcp 0 0 127.0.0.1:45742 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45963 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45862 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45698 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45707 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:6600 127.0.0.1:39035 TIME_WAIT -
tcp 0 0 127.0.0.1:46111 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45729 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46090 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46045 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45949 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45916 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46156 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45737 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45748 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45746 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46121 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46149 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46056 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45849 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45978 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45756 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46155 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45836 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46133 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46011 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45788 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46107 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45872 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45959 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46118 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45876 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46078 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45898 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45881 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46057 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45823 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45975 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45787 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46137 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45896 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45813 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45731 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46001 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46157 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45703 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46016 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45988 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45902 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45761 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45927 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46070 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45965 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46139 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:49399 TIME_WAIT -
tcp 0 0 127.0.0.1:46000 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46071 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45779 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46035 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46052 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45977 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46151 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46109 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46144 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45942 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:49447 TIME_WAIT -
tcp 0 0 127.0.0.1:45825 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45962 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46103 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46138 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45815 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45960 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46081 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45734 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45817 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46060 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45914 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46135 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45895 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46039 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45995 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45844 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46124 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45733 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45776 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45749 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46100 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45786 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45794 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46130 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:49456 TIME_WAIT -
tcp 0 0 127.0.0.1:46099 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45920 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45934 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45891 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45968 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45859 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45699 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46094 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:39062 127.0.0.1:6600 TIME_WAIT -
tcp 0 0 127.0.0.1:46084 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45846 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45808 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45943 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45888 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45921 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45874 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45883 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46087 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45728 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45938 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45829 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46173 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46002 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45866 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45946 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45704 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45792 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45893 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45701 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46161 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45840 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:49466 TIME_WAIT -
tcp 0 0 127.0.0.1:45726 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46008 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46108 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46097 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45727 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45861 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45922 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46013 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45904 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45798 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45702 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46153 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45747 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45913 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46129 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46088 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45970 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46080 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45948 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46067 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46079 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45799 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45925 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45983 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45700 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46004 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45918 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46112 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45812 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46168 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45828 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46007 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45917 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45850 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45697 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45762 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45865 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46076 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45950 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46074 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46091 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45696 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:49724 TIME_WAIT -
tcp 0 0 127.0.0.1:45931 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45773 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46089 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45838 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46106 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46117 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45797 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46026 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:49373 TIME_WAIT -
tcp 0 0 127.0.0.1:45940 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45973 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46165 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46009 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46014 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45985 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45981 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:49382 TIME_WAIT -
tcp 0 0 127.0.0.1:45769 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45736 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46179 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45764 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46167 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45814 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:39452 127.0.0.1:6600 TIME_WAIT -
tcp 0 0 127.0.0.1:45791 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46032 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46042 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46164 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45732 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45832 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46030 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46038 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45718 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45845 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45953 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46110 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46092 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45807 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45890 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46033 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45875 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45884 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45789 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46119 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46115 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46180 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46127 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46031 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45705 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46025 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45766 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45853 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45855 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46143 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46095 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46170 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45880 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45867 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46069 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46176 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45857 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45854 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45783 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45912 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45804 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45993 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45996 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46024 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46162 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46116 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46093 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46141 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45708 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45966 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45856 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46050 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45706 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45821 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46062 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45837 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45714 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46154 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45801 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46085 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46075 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45887 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45848 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45961 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45785 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45869 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45864 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45860 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46058 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46047 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45768 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45947 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46150 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46037 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45878 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45809 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46102 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46160 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45924 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46166 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45842 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45863 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46072 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45852 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46134 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45751 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46169 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45771 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45990 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45730 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45871 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46006 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45740 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46027 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45847 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45858 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46005 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46028 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45715 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45892 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45755 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45997 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46003 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45976 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46101 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46136 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45722 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45757 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45772 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45830 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46066 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45759 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46175 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46142 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45928 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45712 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45831 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46043 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46063 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45980 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46086 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45987 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45982 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45873 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45777 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45782 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45826 127.0.0.1:6379 TIME_WAIT -
