Hi acml,
from your debug log i can clearly see that it is the HDMI audio that makes trouble.
[ 150.134083] [aml-i2s-dai]i2s dma ffffff800064a000,phy addr 1615200256,mode 2,ch 2
[ 150.134088] ----aml_hw_iec958_init,runtime->rate=96000,sample_rate=2--
[ 150.134092] aml_set_spdif_clk rate
[ 150.134105] divider=10,frac=33920000,SDMval=2827
[ 150.134150] set normal 512 fs /4 fs
[ 150.134157] iec958 mode PCM24
[ 150.134160] ----sample_rate==AUDIO_CLK_FREQ_96---
[ 150.134167] IEC958 24bit
[ 150.134173] hdmitx: audio: aout notify rate 96000
[ 150.134177] hdmitx: audio: aout notify size 32
[ 150.134181] hdmtix: set audio
[ 150.134194] hdmitx tx_aud_src = 0
[ 150.134220] hdmitx aud_n_para = 6144
[ 150.134236] hdmitx set channel status
[ 150.134291] 958 with i2s
[ 150.134947] aiu i2s playback enable
[ 150.134973] audio_hw_958_enable 1
[ 163.688089] aiu i2s playback disable
[ 163.688103] audio_hw_958_enable 0
[ 163.850300] [aml-i2s-dai]i2s dma ffffff800064a000,phy addr 1615200256,mode 2,ch 2
[ 163.850311] ----aml_hw_iec958_init,runtime->rate=96000,sample_rate=2--
[ 163.850315] aml_set_spdif_clk rate
[ 163.850327] divider=10,frac=33920000,SDMval=2827
[ 163.850338] set normal 512 fs /4 fs
[ 163.850345] iec958 mode PCM24
[ 163.850349] ----sample_rate==AUDIO_CLK_FREQ_96---
[ 163.850355] IEC958 24bit
[ 163.850361] hdmitx: audio: aout notify rate 96000
[ 163.850365] hdmitx: audio: aout notify size 32
[ 163.850369] 958 with i2s
[ 163.851416] aiu i2s playback enable
[ 163.851442] audio_hw_958_enable 1
[ 173.737825] aiu i2s playback disable
[ 173.737839] audio_hw_958_enable 0
[ 173.891432] [aml-i2s-dai]i2s dma ffffff800064a000,phy addr 1615200256,mode 2,ch 2
[ 173.891444] ----aml_hw_iec958_init,runtime->rate=96000,sample_rate=2--
[ 173.891448] aml_set_spdif_clk rate
[ 173.891459] divider=10,frac=33920000,SDMval=2827
[ 173.891470] set normal 512 fs /4 fs
[ 173.891476] iec958 mode PCM24
[ 173.891479] ----sample_rate==AUDIO_CLK_FREQ_96---
[ 173.891486] IEC958 24bit
[ 173.891491] hdmitx: audio: aout notify rate 96000
[ 173.891495] hdmitx: audio: aout notify size 32
[ 173.891498] 958 with i2s
[ 173.892555] aiu i2s playback enable
[ 173.892575] audio_hw_958_enable 1
[ 183.777598] aiu i2s playback disable
[ 183.777612] audio_hw_958_enable 0
[ 183.948062] [aml-i2s-dai]i2s dma ffffff800064a000,phy addr 1615200256,mode 2,ch 2
[ 183.948074] ----aml_hw_iec958_init,runtime->rate=96000,sample_rate=2--
[ 183.948077] aml_set_spdif_clk rate
[ 183.948088] divider=10,frac=33920000,SDMval=2827
[ 183.948099] set normal 512 fs /4 fs
[ 183.948105] iec958 mode PCM24
[ 183.948108] ----sample_rate==AUDIO_CLK_FREQ_96---
[ 183.948115] IEC958 24bit
[ 183.948121] hdmitx: audio: aout notify rate 96000
[ 183.948124] hdmitx: audio: aout notify size 32
[ 183.948128] 958 with i2s
[ 183.950222] aiu i2s playback enable
[ 183.950246] audio_hw_958_enable 1
[ 193.827366] aiu i2s playback disable
[ 193.827381] audio_hw_958_enable 0
[ 193.978172] [aml-i2s-dai]i2s dma ffffff800064a000,phy addr 1615200256,mode 2,ch 2
[ 193.978184] ----aml_hw_iec958_init,runtime->rate=96000,sample_rate=2--
[ 193.978188] aml_set_spdif_clk rate
[ 193.978199] divider=10,frac=33920000,SDMval=2827
[ 193.978210] set normal 512 fs /4 fs
[ 193.978216] iec958 mode PCM24
[ 193.978219] ----sample_rate==AUDIO_CLK_FREQ_96---
[ 193.978226] IEC958 24bit
[ 193.978232] hdmitx: audio: aout notify rate 96000
[ 193.978236] hdmitx: audio: aout notify size 32
[ 193.978239] 958 with i2s
[ 193.979185] aiu i2s playback enable
[ 193.979212] audio_hw_958_enable 1
[ 203.887140] aiu i2s playback disable
[ 203.887154] audio_hw_958_enable 0
[ 204.041517] [aml-i2s-dai]i2s dma ffffff800064a000,phy addr 1615200256,mode 2,ch 2
[ 204.041529] ----aml_hw_iec958_init,runtime->rate=96000,sample_rate=2--
[ 204.041533] aml_set_spdif_clk rate
[ 204.041545] divider=10,frac=33920000,SDMval=2827
[ 204.041557] set normal 512 fs /4 fs
[ 204.041563] iec958 mode PCM24
[ 204.041566] ----sample_rate==AUDIO_CLK_FREQ_96---
[ 204.041572] IEC958 24bit
[ 204.041577] hdmitx: audio: aout notify rate 96000
[ 204.041581] hdmitx: audio: aout notify size 32
[ 204.041585] 958 with i2s
[ 204.043176] aiu i2s playback enable
[ 204.043208] audio_hw_958_enable 1
[ 213.926910] aiu i2s playback disable
[ 213.926924] audio_hw_958_enable 0
[ 214.076551] [aml-i2s-dai]i2s dma ffffff800064a000,phy addr 1615200256,mode 2,ch 2
[ 214.076564] ----aml_hw_iec958_init,runtime->rate=96000,sample_rate=2--
[ 214.076567] aml_set_spdif_clk rate
[ 214.076578] divider=10,frac=33920000,SDMval=2827
[ 214.076589] set normal 512 fs /4 fs
[ 214.076595] iec958 mode PCM24
[ 214.076598] ----sample_rate==AUDIO_CLK_FREQ_96---
[ 214.076604] IEC958 24bit
[ 214.076611] hdmitx: audio: aout notify rate 96000
[ 214.076614] hdmitx: audio: aout notify size 32
[ 214.076618] 958 with i2s
[ 214.078228] aiu i2s playback enable
[ 214.078256] audio_hw_958_enable 1
[ 223.976685] aiu i2s playback disable
[ 223.976698] audio_hw_958_enable 0
[ 224.142467] [aml-i2s-dai]i2s dma ffffff800064a000,phy addr 1615200256,mode 2,ch 2
[ 224.142479] ----aml_hw_iec958_init,runtime->rate=96000,sample_rate=2--
[ 224.142483] aml_set_spdif_clk rate
[ 224.142494] divider=10,frac=33920000,SDMval=2827
[ 224.142504] set normal 512 fs /4 fs
[ 224.142511] iec958 mode PCM24
[ 224.142514] ----sample_rate==AUDIO_CLK_FREQ_96---
[ 224.142521] IEC958 24bit
[ 224.142528] hdmitx: audio: aout notify rate 96000
[ 224.142531] hdmitx: audio: aout notify size 32
[ 224.142535] 958 with i2s
[ 224.143339] aiu i2s playback enable
[ 224.143363] audio_hw_958_enable 1
[ 234.026465] aiu i2s playback disable
[ 234.026478] audio_hw_958_enable 0
[ 234.219053] [aml-i2s-dai]i2s dma ffffff800064a000,phy addr 1615200256,mode 2,ch 2
[ 234.219065] ----aml_hw_iec958_init,runtime->rate=96000,sample_rate=2--
[ 234.219068] aml_set_spdif_clk rate
[ 234.219079] divider=10,frac=33920000,SDMval=2827
[ 234.219091] set normal 512 fs /4 fs
[ 234.219098] iec958 mode PCM24
[ 234.219101] ----sample_rate==AUDIO_CLK_FREQ_96---
[ 234.219107] IEC958 24bit
[ 234.219113] hdmitx: audio: aout notify rate 96000
[ 234.219117] hdmitx: audio: aout notify size 32
[ 234.219121] 958 with i2s
[ 234.220128] aiu i2s playback enable
[ 234.220158] audio_hw_958_enable 1
[ 244.076230] aiu i2s playback disable
[ 244.076245] audio_hw_958_enable 0
[ 244.222778] [aml-i2s-dai]i2s dma ffffff800064a000,phy addr 1615200256,mode 2,ch 2
[ 244.222791] ----aml_hw_iec958_init,runtime->rate=96000,sample_rate=2--
[ 244.222794] aml_set_spdif_clk rate
[ 244.222806] divider=10,frac=33920000,SDMval=2827
[ 244.222817] set normal 512 fs /4 fs
[ 244.222824] iec958 mode PCM24
[ 244.222827] ----sample_rate==AUDIO_CLK_FREQ_96---
[ 244.222834] IEC958 24bit
[ 244.222839] hdmitx: audio: aout notify rate 96000
[ 244.222843] hdmitx: audio: aout notify size 32
[ 244.222847] 958 with i2s
[ 244.223886] aiu i2s playback enable
[ 244.223914] audio_hw_958_enable 1
[ 254.126007] aiu i2s playback disable
[ 254.126023] audio_hw_958_enable 0
[ 254.276050] [aml-i2s-dai]i2s dma ffffff800064a000,phy addr 1615200256,mode 2,ch 2
[ 254.276062] ----aml_hw_iec958_init,runtime->rate=96000,sample_rate=2--
[ 254.276065] aml_set_spdif_clk rate
[ 254.276077] divider=10,frac=33920000,SDMval=2827
[ 254.276088] set normal 512 fs /4 fs
[ 254.276095] iec958 mode PCM24
[ 254.276098] ----sample_rate==AUDIO_CLK_FREQ_96---
[ 254.276105] IEC958 24bit
[ 254.276111] hdmitx: audio: aout notify rate 96000
[ 254.276114] hdmitx: audio: aout notify size 32
[ 254.276118] 958 with i2s
[ 254.277189] aiu i2s playback enable
[ 254.277216] audio_hw_958_enable 1
[ 264.175757] aiu i2s playback disable
[ 264.175771] audio_hw_958_enable 0
[ 264.327910] [aml-i2s-dai]i2s dma ffffff800064a000,phy addr 1615200256,mode 2,ch 2
[ 264.327923] ----aml_hw_iec958_init,runtime->rate=96000,sample_rate=2--
[ 264.327926] aml_set_spdif_clk rate
[ 264.327938] divider=10,frac=33920000,SDMval=2827
[ 264.327949] set normal 512 fs /4 fs
[ 264.327956] iec958 mode PCM24
[ 264.327959] ----sample_rate==AUDIO_CLK_FREQ_96---
[ 264.327966] IEC958 24bit
[ 264.327973] hdmitx: audio: aout notify rate 96000
[ 264.327976] hdmitx: audio: aout notify size 32
[ 264.327980] 958 with i2s
[ 264.328431] aiu i2s playback enable
[ 264.328462] audio_hw_958_enable 1
[ 274.235527] aiu i2s playback disable
[ 274.235540] audio_hw_958_enable 0
[ 274.381996] [aml-i2s-dai]i2s dma ffffff800064a000,phy addr 1615200256,mode 2,ch 2
[ 274.382008] ----aml_hw_iec958_init,runtime->rate=96000,sample_rate=2--
[ 274.382011] aml_set_spdif_clk rate
[ 274.382023] divider=10,frac=33920000,SDMval=2827
[ 274.382033] set normal 512 fs /4 fs
[ 274.382039] iec958 mode PCM24
[ 274.382042] ----sample_rate==AUDIO_CLK_FREQ_96---
[ 274.382049] IEC958 24bit
[ 274.382055] hdmitx: audio: aout notify rate 96000
[ 274.382058] hdmitx: audio: aout notify size 32
[ 274.382062] 958 with i2s
[ 274.383647] aiu i2s playback enable
[ 274.383675] audio_hw_958_enable 1
[ 279.085516] aiu i2s playback disable
[ 279.085531] audio_hw_958_enable 0
So please also try to disable it (see post above)
You also have DSD_USB enabled, please disable it and try again.
name "Cayin iDAC-6"
device "hw:1,0"
dsd_usb "yes"
BTW: Is the DAC self powered or via USB?
