Hi all,
here are some notes to the ODROID C2 image.
- it is a first test image
- image runs in dev mode (maybe a little bit slower)
- Spotify does not work, because there is no 64 library available.
- the filesystem is read only (ro)*
- support for IR remote is implemented**
- native DSD via USB is implemented
- local browser optimized for ODROID VU7 (7inch 800x480 HDMI display) is implemented (MENU->Settings->Local browser)
- lyrics by hovering over album art (can be disabled in database "redis-cli set lyric 0")
- mpd-watchdog is enabled by default, this can be especially useful when playing internet streams.
- I2S support for ODROID HiFi shield (MENU->Settings->I²S kernel modules)
The image runs with the filesystem mounted as read only.
Sudden power loss, unproper shutdown or pulling the plug can't damage the filesystem anymore.
This also will extend the lifetime of your sd card, because typical flash memory can only tolerate limited number of write cycles without being worn out.
The only thing you have to consider is:
All changes (add network shares, updating mpd library ....) will be discarded when cutting power without proper shutdown.
The file system can be made temporarily read write on the console:
root@runeaudio(ro):/#
root@runeaudio(ro):/# set_rw
root@runeaudio(rw):/#
root@runeaudio(rw):/# set_ro
Lirc is activated by default and configured for the
ODROID IR Remote Controller.
The configuration files are in "/etc/lirc" and have to be adapted for other remotes.
With the ODROID remote you can power down or reboot the device by holding the power button for more than 5 seconds.
PS: As usual, sorry for my bad english.
