I've read from ACX (thanks for the answer and your work), that the new version will work with HifiBerry+ (DAC/Digi) out-of-the box, but though I don't know anything about it's release date, I would like to ask if:
Anyone managed to make Hifiberry+ work with of course PI model B+?
On HifiBerry site it is written that kernel upgrade solves the problem, but I think not. (
http://www.hifiberry.com/guides/supportedsoftware/)
I've also tried module setup described here:
http://www.hifiberry.com/guides/hifiberry-software-configuration/ with no luck.
When I'm trying to use Digi+ and starting to play, the complete USB subsystem stops working including the ethernet connector. This problem seems to come after pri-update.
Can anyone tell me some guidelines about the change?
- I guess, that model B+/Digi+ differs from the original just in the pinout.
- Where do I have to follow this change? In the kernel module? rpi-update does not solve this?
- Maybe the new kernel is needed for the PI model B+, and also a new module that handles HifiBerry Digi+?
Thanks for any information, that helps.
