MarmiteSandwich For anybody still struggling to get a USB IR remote to work with the RP3, try this post: #3901 Regards, Marmite
Darioia Hi I think that's the problem regards the GPIO's enable procedure. I am using BCM GPIO 23 (J8 pin 16 on rpi3 rev B), I have added in config.txt the following line: dtoverlay=lirc-rpi,gpio_in_pin=23,gpio_out_pin=22,gpio_in_pull=up I have solved the problem using a python script: #!/usr/bin/python2 import RPi.GPIO as gpio gpio.setmode(gpio.BCM) gpio.setup(23, gpio.IN, pull_up_down=gpio.PUD_UP) gpio.cleanup() exit() After that command mode2 command works but irw not receive nothing. I suppose now the problem is lircd.conf (I use Acer RC804V-B model). Dario
