Hi Uwe,
i have absolutely no idea what you are doing.
I tested this on multiple devices with different networks and it worked each time.
I have no clue whether the numbers for primary and secondary DNS are correct (it is 8.8.8.8 and 2001:4850:4860:8844).
"8.8.8.8" is googles DNS server and "2001:4850:4860:8844" is its ipv6 equivalent.
Normally it's sufficient to use your routers ip as primary DNS, but using googles Domain Name System (DNS) may speed up your internet connection.
I was also surprised that netmask is 255.255.0.0 (I thought it should be 255.255.255.0).
Depending on your local network, "255.255.0.0" could be the right netmask.
All these numbers are from a previous attempt to connect with DHCP.
With dchp it is not possible to save the wlan0 profile ...
What do you mean with "not possible"? Is there a error message?
Did you delete the profile for your visible SSID first? If not you should do so.
Did you follow my howto from the last post step by step?
Your wifi works with a visible SSID, correct?
If so, please setup a profile on rune with this visible SSID.
Next get access to the console and find / edit this profile.
All you have to do is to add the line:
'scan_ssid=1'
to the WPAConfigSection.
Description='wlan0 connection'
Interface=wlan0
Connection=wireless
Security=wpa-configsection
IP=dhcp
WPAConfigSection=(
'ssid="NETGEAR"'
'scan_ssid=1'
'psk="xxxxxxxxxxxxxxx"'
'key_mgmt=WPA-PSK'
'proto=WPA'
'group=TKIP'
'pairwise=TKIP'
'priority=3'
