Hi hondagx35,
I noticed some "bugs"...
1) the keyboard is not popping up when I want to add webradio stations, also when I want to save a playlist, the same issue...
2) I don't know if that's also the case if you use the 7inch touchscreen (I have a 5inch), but I have a small space over the header where I see the main screen scrolling past when using e.g. playlist. The gap over the header bar dissapears when I use command out the custom midori style sheet to have the smaler fonts...
3) Everytime I "click" on something, a little framed box showing the link address is popping up either on the bottom left or right side... can this be avoided?
4) How do I get rid of the small colour square in the top-right, it's kind of blocking the visibility of the menu drop bar.
5) Rotating of the screen doesn't seem to do anything... changing
lcd_rotate=2
to
lcd_rotate=0
should rotate the screen by 180° but its still the same. I'd like to try how it looks like when I turn it 90°, how can I do that?
6) Do you have a solution for the occasional crashing when you click fast in a row? Anthing promissing yet with other browsers?
Thanks for this great piece of art!
