Hi AlleyCat,
Any reply?
try this :
Adjust the code in /root/.xinitrc
xset -dpms
to
xset dpms 0 0 600
It will shut down the display after 10 minutes of inactivity. It will switch back on immediately when touching the display.
- Get access to the console:
Use SSH from your PC
- If you are not familiar with SSH read this for Windows or this for Linux/MacOS
The default login for RuneAudio is "root" with the password "rune" (without quotes).
- Use sftp to access files on Rune Audio:
Get WinSCP from
here and install it.
When it opens setup the following:
- Session
File Protocol: SCP
Host name: The IP address of your Raspberry Pi
User name: root
Password: rune
That's it, connect and you can transfer files just by dragging and dropping.
