Thank you very much smallfat, but ....
excuse me:
smallfat wrote1. Write 7" IMG file to SD card
1) - What's the 7 "IMG and on what page I can download it ?
1a) - However on the SD I have flashed this IMG:
http://sourceforge.net/projects/runeaudio/files/Images/ODROID%20C1%28%2B%29/RuneAudio_odroid-c1_0.3-dev_20150824_2GB.img.gz/download
2) - According to the post:
"Module-loading-for-TFT-t3010.html"
I understood that I have to write the line:
nano /etc/modules-load.d/odroid_tft.conf
and then copy / paste:
# /etc/modules-load.d Conf file for ODROID 3 "TFT 2
## SPI modules for 3 "TFT 2
spicc
# Spidev and ADS7846 Should be pulled automatically
#spidev
# ADS7846
## FB modules for 3 "TFT 2 (parameters set forth modprobe.d)
fbtft_device
# These Should be pulled automatically
# Fb_odroidc_tft32
#fbtft
#fb_sys_fops
#sysimgblt
#sysfillrect
#syscopyarea
Then I write: nano /etc/modprobe.d/fbtft_device.conf
and I have copy / paste:
# /etc/modprobe.d Conf file for ODROID 3 "TFT 2 fbtft options
## Options for 3 "2 TFT module (s)
options fbtft_device name = odroidc_tft32
options fbtft_device rotate = 270
options fbtft_device GPIOs = reset: 116 AD: 115
options fbtft_device speed = 32000000
options fbtft_device cs = 0
3) - Then the post says:
Install these, I do not forget to remove the now obsolete modprobes from .bash_profile, reboot, and have fun.
How can I do this exactly?
4) - You say:
"Remember ignore section Regarding .bash_profile Which is incorrect and was corrected by post above."
So I started from the point where it says:
And create a file "/usr/share/X11/xorg.conf.d/99-odroidc-tftlcd.conf" and paste the below configuration to display X11 on the TFT.
Code: Select all
Section "Device"
Identifier "C1 fbdev"
Driver "fbdev"
Option "fbdev" "/ dev / fb2"
EndSection
Save it and reboot, you can see the RuneAudio on the 3.2inch LCD.
Time to calibrate the resistive touch screen. Install the calibrator.
Code: Select all
pacman -S xinput_calibrator
It's all correct everything I've written?
Is this the correct procedure?
If Is this the right procedure, I've done all these steps and I restarted the device but the TFT yet none of it to work .....
Where am I wrong?
Many thanks in advance !
