Frank:
on your advice, I got a P2 and set it up with Rune. First off- HUGE improvement in the responsiveness. Very cool.
I followed a similar setup to what we did before, (abcde, cdrkit, eject...whatever the dependencies were) and everything loads easily.
Tagging, cover art and file names all is just fine.
Here is my config:
used your config file and the only error i get is:
which: no glyrc in (/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl)
[ERROR] abcde: glyrc is not in your path.
[INFO] Define the full path to the executable if it exists on your system.
so it looks like glyrc is all that i need? I got the package and have tried to compile but the errors i get back dont make a lot of sense-i figure i did something wrong...
any direction you could point me to solve that would be greatly appreciated.
thanks again for the suggestion to the RP2!
-j
EDIT------>>>
So I actually started over again from scratch, new Rune install, pacman'd abcde/eject/cdparanoia/id3/cdrkit and without altering a line - the damn thing worked. In WAV format but i am working through the config...got it to ogg without error, but flac still is a PITA.
So i know im close (thanks to you felllas). I try copying Frank's config and I still get the same
glyrc issues.. so I will keep trying and learning and breaking things... thanks guys
