macy I have just installed Rune, before that I had run the other product on. Since the hard drive has worked with Rune not. Is there a solution?
flipdacrip Hi, you should specify your problem more detailed, i think no one knows what to do with such a description. regards
Mat RPI does not provide enough current on USB ports by default. Just add this in config.txt file: safe_mode_gpio=4 max_usb_current=1 And make sure that your adapter has enough power. I use 2A adapter and it works perfect.
macy I'm going to replace the HUB, but I have been a turn. https://www.yepkit.com/products/ykush And so far it has functioned. But thanks for the note.
macy Ok, it has with the new HUB works immediately. Unfortunately, however, comes with HDMI out no sound. This went with Volumio
