@[deleted]: PM sent
@all
I ran into a problem when switching to a static IP address, which I temporarily fixed.
From other posts it is a know problem and being addressed.
Small problem, but curious why DSF files don't not work (small because I don't have many of them).
From the mpd.log you can see it addresses Alsa device "hw:0,0" while "hw:1,0" has being configured.
Alsa device "hw:0,0" is the onboard card, which only handles 16bit pcm.
I probably have made a mistake here.
May 22 20:28 : alsa_output: opened hw:0,0 type=HW
May 22 20:28 : alsa_output: format=S16_LE (Signed 16 bit Little Endian)
May 22 20:28 : alsa_output: buffer: size=2048..32768 time=21333..341334
May 22 20:28 : alsa_output: period: size=1024..2048 time=10666..21334
May 22 20:28 : alsa_output: default period_time = buffer_time/4 = 341333/4 = 85333
May 22 20:28 : alsa_output: buffer_size=32768 period_size=2048
May 22 20:28 : alsa_output: Failed to open "Built-in Audio" [alsa]: Failed to configure DSD-over-PCM on ALSA device "hw:0,0"
The mpd and alsa configuration is from the debug log:
Advanced Linux Sound Architecture Driver Version k3.8.13.29-2-ARCH.
0 [Audio ]: Built-in_Audio - Built-in Audio
Built-in Audio
1 [HIFIRef ]: USB-Audio - HIFI-Ref
XMOS HIFI-Ref at usb-s5p-ehci-2.1.5, high speed
PLAYBACK devices: (aplay -l)
card 0: Audio [Built-in Audio], device 0: Playback HiFi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: Audio [Built-in Audio], device 1: Capture HiFi-1 []
Subdevices: 1/1
card 1: HIFIRef [HIFI-Ref], device 0: USB Audio [USB Audio]
Subdevices: 1/1
PCM devices: (aplay -L)
null
default:CARD=Audio
Built-in Audio,
Default Audio Device
sysdefault:CARD=Audio
Built-in Audio,
default:CARD=HIFIRef
HIFI-Ref, USB Audio
sysdefault:CARD=HIFIRef
HIFI-Ref, USB Audio
front:CARD=HIFIRef,DEV=0
HIFI-Ref, USB Audio
Front speakers
surround21:CARD=HIFIRef,DEV=0
HIFI-Ref, USB Audio
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=HIFIRef,DEV=0
HIFI-Ref, USB Audio
4.0 Surround output to Front and Rear speakers
surround41:CARD=HIFIRef,DEV=0
HIFI-Ref, USB Audio
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=HIFIRef,DEV=0
HIFI-Ref, USB Audio
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=HIFIRef,DEV=0
HIFI-Ref, USB Audio
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=HIFIRef,DEV=0
HIFI-Ref, USB Audio
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=HIFIRef,DEV=0
HIFI-Ref, USB Audio
IEC958 (S/PDIF) Digital Audio Output
card 0:
Simple mixer control 'Headphone',0
Simple mixer control 'Headphone Left',0
Simple mixer control 'Headphone Left Mixer',0
Simple mixer control 'Headphone Right',0
Simple mixer control 'Headphone Right Mixer',0
Simple mixer control 'Speaker',0
Simple mixer control 'Speaker Left',0
Simple mixer control 'Speaker Left Mixer',0
Simple mixer control 'Speaker Right',0
Simple mixer control 'Speaker Right Mixer',0
Simple mixer control 'Playback Path DC Blocking',0
Simple mixer control 'ADC High Performance Mode',0
Simple mixer control 'ADC Oversampling Rate',0
Simple mixer control 'ADC Quantizer Dither',0
Simple mixer control 'ADCL',0
Simple mixer control 'ADCL Boost',0
Simple mixer control 'ADCR',0
Simple mixer control 'ADCR Boost',0
Simple mixer control 'ALC Attack Time',0
Simple mixer control 'ALC Compression Ratio',0
Simple mixer control 'ALC Compression Threshold',0
Simple mixer control 'ALC Enable',0
Simple mixer control 'ALC Expansion Ratio',0
Simple mixer control 'ALC Expansion Threshold',0
Simple mixer control 'ALC Make Up',0
Simple mixer control 'ALC Release Time',0
Simple mixer control 'Biquad',0
Simple mixer control 'DAC HP Playback Performance Mode',0
Simple mixer control 'DAC High Performance Mode',0
Simple mixer control 'DAC Mono Mode',0
Simple mixer control 'DMIC MIC Comp Filter Config',0
Simple mixer control 'DMIC Mux',0
Simple mixer control 'Digital',0
Simple mixer control 'Digital BQ',0
Simple mixer control 'Digital Coarse',0
Simple mixer control 'Digital EQ',0
Simple mixer control 'Digital EQ 3 Band',0
Simple mixer control 'Digital EQ 5 Band',0
Simple mixer control 'Digital EQ 7 Band',0
Simple mixer control 'Digital EQ Clipping Detection',0
Simple mixer control 'Digital Sidetone',0
Simple mixer control 'Enhanced Vol Smoothing',0
Simple mixer control 'Filter Mode',0
Simple mixer control 'LBENL Mux',0
Simple mixer control 'LBENR Mux',0
Simple mixer control 'LINEA',0
Simple mixer control 'LINEA Ext Resistor Gain Mode',0
Simple mixer control 'LINEA Mixer IN1',0
Simple mixer control 'LINEA Mixer IN3',0
Simple mixer control 'LINEA Mixer IN34',0
Simple mixer control 'LINEA Mixer IN5',0
Simple mixer control 'LINEA Single Ended',0
Simple mixer control 'LINEB',0
Simple mixer control 'LINEB Ext Resistor Gain Mode',0
Simple mixer control 'LINEB Mixer IN2',0
Simple mixer control 'LINEB Mixer IN4',0
Simple mixer control 'LINEB Mixer IN56',0
Simple mixer control 'LINEB Mixer IN6',0
Simple mixer control 'LINEB Single Ended',0
Simple mixer control 'LINMOD Mux',0
Simple mixer control 'LTENL Mux',0
Simple mixer control 'LTENR Mux',0
Simple mixer control 'Left ADC Mixer IN12',0
Simple mixer control 'Left ADC Mixer IN34',0
Simple mixer control 'Left ADC Mixer IN56',0
Simple mixer control 'Left ADC Mixer LINEA',0
Simple mixer control 'Left ADC Mixer LINEB',0
Simple mixer control 'Left ADC Mixer MIC1',0
Simple mixer control 'Left ADC Mixer MIC2',0
Simple mixer control 'Left Headphone Mixer LINEA',0
Simple mixer control 'Left Headphone Mixer LINEB',0
Simple mixer control 'Left Headphone Mixer Left DAC',0
Simple mixer control 'Left Headphone Mixer MIC1',0
Simple mixer control 'Left Headphone Mixer MIC2',0
Simple mixer control 'Left Headphone Mixer Right DAC',0
Simple mixer control 'Left Receiver Mixer LINEA',0
Simple mixer control 'Left Receiver Mixer LINEB',0
Simple mixer control 'Left Receiver Mixer Left DAC',0
Simple mixer control 'Left Receiver Mixer MIC1',0
Simple mixer control 'Left Receiver Mixer MIC2',0
Simple mixer control 'Left Receiver Mixer Right DAC',0
Simple mixer control 'Left Speaker Mixer LINEA',0
Simple mixer control 'Left Speaker Mixer LINEB',0
Simple mixer control 'Left Speaker Mixer Left DAC',0
Simple mixer control 'Left Speaker Mixer MIC1',0
Simple mixer control 'Left Speaker Mixer MIC2',0
Simple mixer control 'Left Speaker Mixer Right DAC',0
Simple mixer control 'MIC Bias VCM Bandgap',0
Simple mixer control 'MIC1',0
Simple mixer control 'MIC1 Boost',0
Simple mixer control 'MIC1 Mux',0
Simple mixer control 'MIC2',0
Simple mixer control 'MIC2 Boost',0
Simple mixer control 'MIC2 Mux',0
Simple mixer control 'MIXHPLSEL Mux',0
Simple mixer control 'MIXHPRSEL Mux',0
Simple mixer control 'Receiver',0
Simple mixer control 'Receiver Left',0
Simple mixer control 'Receiver Left Mixer',0
Simple mixer control 'Receiver Right',0
Simple mixer control 'Receiver Right Mixer',0
Simple mixer control 'Record Path DC Blocking',0
Simple mixer control 'Right ADC Mixer IN12',0
Simple mixer control 'Right ADC Mixer IN34',0
Simple mixer control 'Right ADC Mixer IN56',0
Simple mixer control 'Right ADC Mixer LINEA',0
Simple mixer control 'Right ADC Mixer LINEB',0
Simple mixer control 'Right ADC Mixer MIC1',0
Simple mixer control 'Right ADC Mixer MIC2',0
Simple mixer control 'Right Headphone Mixer LINEA',0
Simple mixer control 'Right Headphone Mixer LINEB',0
Simple mixer control 'Right Headphone Mixer Left DAC',0
Simple mixer control 'Right Headphone Mixer MIC1',0
Simple mixer control 'Right Headphone Mixer MIC2',0
Simple mixer control 'Right Headphone Mixer Right DAC',0
Simple mixer control 'Right Receiver Mixer LINEA',0
Simple mixer control 'Right Receiver Mixer LINEB',0
Simple mixer control 'Right Receiver Mixer Left DAC',0
Simple mixer control 'Right Receiver Mixer MIC1',0
Simple mixer control 'Right Receiver Mixer MIC2',0
Simple mixer control 'Right Receiver Mixer Right DAC',0
Simple mixer control 'Right Speaker Mixer LINEA',0
Simple mixer control 'Right Speaker Mixer LINEB',0
Simple mixer control 'Right Speaker Mixer Left DAC',0
Simple mixer control 'Right Speaker Mixer MIC1',0
Simple mixer control 'Right Speaker Mixer MIC2',0
Simple mixer control 'Right Speaker Mixer Right DAC',0
Simple mixer control 'SDIN Mode',0
Simple mixer control 'SDOUT Hi-Z Mode',0
Simple mixer control 'SDOUT Mode',0
Simple mixer control 'STENL Mux',0
Simple mixer control 'STENR Mux',0
Simple mixer control 'Volume Adjustment Smoothing',0
Simple mixer control 'Zero-Crossing Detection',0
card 1:
Simple mixer control 'iAP Interface',0
Simple mixer control 'iAP Interface',1
card 0:
numid=47,iface=MIXER,name='Headphone Left Mixer Volume'
numid=56,iface=MIXER,name='Headphone Left Switch'
numid=48,iface=MIXER,name='Headphone Right Mixer Volume'
numid=57,iface=MIXER,name='Headphone Right Switch'
numid=53,iface=MIXER,name='Headphone Volume'
numid=19,iface=MIXER,name='ADC High Performance Mode'
numid=17,iface=MIXER,name='ADC Oversampling Rate'
numid=18,iface=MIXER,name='ADC Quantizer Dither'
numid=13,iface=MIXER,name='ADCL Boost Volume'
numid=15,iface=MIXER,name='ADCL Volume'
numid=14,iface=MIXER,name='ADCR Boost Volume'
numid=16,iface=MIXER,name='ADCR Volume'
numid=26,iface=MIXER,name='Playback Path DC Blocking'
numid=38,iface=MIXER,name='ALC Attack Time'
numid=41,iface=MIXER,name='ALC Compression Ratio'
numid=43,iface=MIXER,name='ALC Compression Threshold Volume'
numid=37,iface=MIXER,name='ALC Enable'
numid=42,iface=MIXER,name='ALC Expansion Ratio'
numid=44,iface=MIXER,name='ALC Expansion Threshold Volume'
numid=40,iface=MIXER,name='ALC Make Up Volume'
numid=39,iface=MIXER,name='ALC Release Time'
numid=65,iface=MIXER,name='Biquad Coefficients'
numid=66,iface=MIXER,name='Biquad Switch'
numid=45,iface=MIXER,name='DAC HP Playback Performance Mode'
numid=46,iface=MIXER,name='DAC High Performance Mode'
numid=20,iface=MIXER,name='DAC Mono Mode'
numid=2,iface=MIXER,name='DMIC MIC Comp Filter Config'
numid=134,iface=MIXER,name='DMIC Mux'
numid=27,iface=MIXER,name='Digital BQ Volume'
numid=29,iface=MIXER,name='Digital Coarse Volume'
numid=32,iface=MIXER,name='Digital EQ 3 Band Switch'
numid=33,iface=MIXER,name='Digital EQ 5 Band Switch'
numid=34,iface=MIXER,name='Digital EQ 7 Band Switch'
numid=35,iface=MIXER,name='Digital EQ Clipping Detection'
numid=36,iface=MIXER,name='Digital EQ Volume'
numid=28,iface=MIXER,name='Digital Sidetone Volume'
numid=30,iface=MIXER,name='Digital Volume'
numid=31,iface=MIXER,name='EQ Coefficients'
numid=63,iface=MIXER,name='Enhanced Vol Smoothing'
numid=24,iface=MIXER,name='Filter Mode'
numid=111,iface=MIXER,name='LBENL Mux'
numid=110,iface=MIXER,name='LBENR Mux'
numid=11,iface=MIXER,name='LINEA Ext Resistor Gain Mode'
numid=130,iface=MIXER,name='LINEA Mixer IN1 Switch'
numid=131,iface=MIXER,name='LINEA Mixer IN3 Switch'
numid=133,iface=MIXER,name='LINEA Mixer IN34 Switch'
numid=132,iface=MIXER,name='LINEA Mixer IN5 Switch'
numid=7,iface=MIXER,name='LINEA Single Ended Volume'
numid=9,iface=MIXER,name='LINEA Volume'
numid=12,iface=MIXER,name='LINEB Ext Resistor Gain Mode'
numid=126,iface=MIXER,name='LINEB Mixer IN2 Switch'
numid=127,iface=MIXER,name='LINEB Mixer IN4 Switch'
numid=129,iface=MIXER,name='LINEB Mixer IN56 Switch'
numid=128,iface=MIXER,name='LINEB Mixer IN6 Switch'
numid=8,iface=MIXER,name='LINEB Single Ended Volume'
numid=10,iface=MIXER,name='LINEB Volume'
numid=69,iface=MIXER,name='LINMOD Mux'
numid=109,iface=MIXER,name='LTENL Mux'
numid=108,iface=MIXER,name='LTENR Mux'
numid=119,iface=MIXER,name='Left ADC Mixer IN12 Switch'
numid=120,iface=MIXER,name='Left ADC Mixer IN34 Switch'
numid=121,iface=MIXER,name='Left ADC Mixer IN56 Switch'
numid=122,iface=MIXER,name='Left ADC Mixer LINEA Switch'
numid=123,iface=MIXER,name='Left ADC Mixer LINEB Switch'
numid=124,iface=MIXER,name='Left ADC Mixer MIC1 Switch'
numid=125,iface=MIXER,name='Left ADC Mixer MIC2 Switch'
numid=102,iface=MIXER,name='Left Headphone Mixer LINEA Switch'
numid=103,iface=MIXER,name='Left Headphone Mixer LINEB Switch'
numid=100,iface=MIXER,name='Left Headphone Mixer Left DAC Switch'
numid=104,iface=MIXER,name='Left Headphone Mixer MIC1 Switch'
numid=105,iface=MIXER,name='Left Headphone Mixer MIC2 Switch'
numid=101,iface=MIXER,name='Left Headphone Mixer Right DAC Switch'
numid=78,iface=MIXER,name='Left Receiver Mixer LINEA Switch'
numid=79,iface=MIXER,name='Left Receiver Mixer LINEB Switch'
numid=76,iface=MIXER,name='Left Receiver Mixer Left DAC Switch'
numid=80,iface=MIXER,name='Left Receiver Mixer MIC1 Switch'
numid=81,iface=MIXER,name='Left Receiver Mixer MIC2 Switch'
numid=77,iface=MIXER,name='Left Receiver Mixer Right DAC Switch'
numid=90,iface=MIXER,name='Left Speaker Mixer LINEA Switch'
numid=91,iface=MIXER,name='Left Speaker Mixer LINEB Switch'
numid=88,iface=MIXER,name='Left Speaker Mixer Left DAC Switch'
numid=92,iface=MIXER,name='Left Speaker Mixer MIC1 Switch'
numid=93,iface=MIXER,name='Left Speaker Mixer MIC2 Switch'
numid=89,iface=MIXER,name='Left Speaker Mixer Right DAC Switch'
numid=1,iface=MIXER,name='MIC Bias VCM Bandgap'
numid=3,iface=MIXER,name='MIC1 Boost Volume'
numid=136,iface=MIXER,name='MIC1 Mux'
numid=5,iface=MIXER,name='MIC1 Volume'
numid=4,iface=MIXER,name='MIC2 Boost Volume'
numid=135,iface=MIXER,name='MIC2 Mux'
numid=6,iface=MIXER,name='MIC2 Volume'
numid=68,iface=MIXER,name='MIXHPLSEL Mux'
numid=67,iface=MIXER,name='MIXHPRSEL Mux'
numid=51,iface=MIXER,name='Receiver Left Mixer Volume'
numid=60,iface=MIXER,name='Receiver Left Switch'
numid=52,iface=MIXER,name='Receiver Right Mixer Volume'
numid=61,iface=MIXER,name='Receiver Right Switch'
numid=55,iface=MIXER,name='Receiver Volume'
numid=25,iface=MIXER,name='Record Path DC Blocking'
numid=112,iface=MIXER,name='Right ADC Mixer IN12 Switch'
numid=113,iface=MIXER,name='Right ADC Mixer IN34 Switch'
numid=114,iface=MIXER,name='Right ADC Mixer IN56 Switch'
numid=115,iface=MIXER,name='Right ADC Mixer LINEA Switch'
numid=116,iface=MIXER,name='Right ADC Mixer LINEB Switch'
numid=117,iface=MIXER,name='Right ADC Mixer MIC1 Switch'
numid=118,iface=MIXER,name='Right ADC Mixer MIC2 Switch'
numid=96,iface=MIXER,name='Right Headphone Mixer LINEA Switch'
numid=97,iface=MIXER,name='Right Headphone Mixer LINEB Switch'
numid=94,iface=MIXER,name='Right Headphone Mixer Left DAC Switch'
numid=98,iface=MIXER,name='Right Headphone Mixer MIC1 Switch'
numid=99,iface=MIXER,name='Right Headphone Mixer MIC2 Switch'
numid=95,iface=MIXER,name='Right Headphone Mixer Right DAC Switch'
numid=72,iface=MIXER,name='Right Receiver Mixer LINEA Switch'
numid=73,iface=MIXER,name='Right Receiver Mixer LINEB Switch'
numid=70,iface=MIXER,name='Right Receiver Mixer Left DAC Switch'
numid=74,iface=MIXER,name='Right Receiver Mixer MIC1 Switch'
numid=75,iface=MIXER,name='Right Receiver Mixer MIC2 Switch'
numid=71,iface=MIXER,name='Right Receiver Mixer Right DAC Switch'
numid=84,iface=MIXER,name='Right Speaker Mixer LINEA Switch'
numid=85,iface=MIXER,name='Right Speaker Mixer LINEB Switch'
numid=82,iface=MIXER,name='Right Speaker Mixer Left DAC Switch'
numid=86,iface=MIXER,name='Right Speaker Mixer MIC1 Switch'
numid=87,iface=MIXER,name='Right Speaker Mixer MIC2 Switch'
numid=83,iface=MIXER,name='Right Speaker Mixer Right DAC Switch'
numid=21,iface=MIXER,name='SDIN Mode'
numid=23,iface=MIXER,name='SDOUT Hi-Z Mode'
numid=22,iface=MIXER,name='SDOUT Mode'
numid=107,iface=MIXER,name='STENL Mux'
numid=106,iface=MIXER,name='STENR Mux'
numid=49,iface=MIXER,name='Speaker Left Mixer Volume'
numid=58,iface=MIXER,name='Speaker Left Switch'
numid=50,iface=MIXER,name='Speaker Right Mixer Volume'
numid=59,iface=MIXER,name='Speaker Right Switch'
numid=54,iface=MIXER,name='Speaker Volume'
numid=64,iface=MIXER,name='Volume Adjustment Smoothing'
numid=62,iface=MIXER,name='Zero-Crossing Detection'
card 1:
numid=1,iface=MIXER,name='iAP Interface Playback Switch'
numid=2,iface=MIXER,name='iAP Interface Playback Switch',index=1
numid=3,iface=MIXER,name='iAP Interface Playback Volume'
numid=4,iface=MIXER,name='iAP Interface Playback Volume',index=1
Output 1 (HIFI-Ref) is enabled
Output 2 (Built-in Audio) is enabled
log_level "verbose"
zeroconf_name "RuneAudio"
auto_update "no"
audio_buffer_size "2048"
buffer_before_play "10%"
enabled "no"
name "HIFI-Ref"
device "hw:1,0"
mixer_type "hardware"
mixer_device "hw:hw:1,0"
mixer_control ",0"
mixer_index "0"
dsd_usb "yes"
name "Built-in Audio"
mixer_device "hw:hw:0,0"
mixer_control ",0"
mixer_index "0"
dsd_usb "yes"
