OK, I have a serious issue with the patch (nightly build) to get Dirble working again...
Setup:
RasPi B+
Audioponics Sabre ES9023 (ebay copy, works as Hifiberry...)
Standard RuneAudio image (RuneAudio_rpi_0.3-beta_20141029_2GB.img)
Once set up for Audiphonics DAC, everything works OK - except Dirble....
So, I followed Frank's advice to get it to work, i.e. switch to nightly build:
rm -rf /var/www/{*,.*}
git clone -b dev https://github.com/RuneAudio/RuneUI.git/ /var/www
curl -s http://localhost/clear
- and reboot
After reboot, everything works (including Dirble, although it shows "null")
However, once I try to reboot or shutdown again from the UI, it starts the spinning circle and does not shut down or reboot.... just waits.
If I ssh into Rune, and issue "shutdown -r now" or "shutdown -h now", it shuts down/reboots, but...
- I don't have either the network or the UI, anything... If I connect the RasPi to a monitor, I see a "normal" start of the boot process, but after a few seconds it throws me into a login prompt! (in console).
So, no network, no UI, just a login prompt in the console...
I've tried this process several times, always with the same result: at first reboot after switch to nightly build, everything seems to be OK, but on subsequent reboots the system does not start, but opens a console login prompt...
Any pointers?
Or a clear and bulletproof instructions to get Dirble to work again on RasPi B+?
TIA,
Denis
