hondagx35 wroteHi all,
i have made a new image for this combo (Odroid C1+ and HiFi shield).
It sounds very good so far (tested up to 24/192).
It will be soon available here.
@Gé
please can you test it (i'll send you a link tomorrow).
the new image works really well with the C1+ and HiFi shield combo, I tested following sample rates:
16/ 44.1, 24/ 44.1, 24/ 48, 24/ 88.2, 24/ 192
And then the icing on the cake
: 24bit/ 352.8Khz also works, tested with many different albums and tracks.
To make sure that this was correct and no resampling was done, I checked hw_params in /proc/asound/card1/pcm0p/sub0 each time.
The I2S Interface also works with my cheap chinese Teradak ES9036.
It is recognized as an ODROIDDAC, the aml soc driver is handling it properly, so it is great value for money with up to 24bit/192Khz.
For the rest, the new RuneAudio image is fully compatible with the older C1.
It can be used without modification, but it might be better to disable the DAC in boot.ini
General suggestions for boot.ini: disable hdmi and video decoding as we do not need that for RA.
Spotify works with the HiFi shield
I have not tested USB Audio, WiFi, Airplay, Webradio or any other RA feature (yet).
Gé
