Cubietrucks + DIYINHK Xmos + ES9018 DSD don't play
Cubietruck related support
Postby papino » 29 Jul 2015, 21:07
Hi all
I had put in place the chain Cubietrucks + DIYINHK Xmos + ES9018 , every things works well with all kind of file format (FLAC , Wmv et etc ) and at every kind of resolution. Unfortunately DSD format won't play ( i had try many format but without succes ) . Anyone had experieced this kind of issue ?
any suggestion will be more than well accepted , if this issue could be solved probaly this player is the best in class , actually is in my system near to a Pioneer N55 as player and M2Tech Evo as converter
all the best
papino
Re: Cubietrucks + DIYINHK Xmos + ES9018 DSD don't play
Postby Abra » 09 Mar 2016, 10:46
Seems to be solved. It works fine with different diyinhk XMOS (isolated, non-isolated) and also without XMOS (with I2S). With both of diyinhk ES9018S and ES9018K2M dac boards.
Abra
Postby rivershaky » 15 Mar 2020, 16:20
Thanks for the quick reply! :D
rivershaky
Return to Cubietruck
