Re: RuneAudio+R e6
Posted:
04 Mar 2021, 18:36
by cmh714
kiko wrote:Strange, it does not work for me.
It plays with no issue using VLC on my MacBook Pro
I'm running rAudio 1 20210302 on a Raspberry PI 3b
I am fully updated and as I said its working here....I also update the OS via pacman and there were some damn big updates this week.....
Re: RuneAudio+R e6
Posted:
04 Mar 2021, 18:42
by kiko
Thanks for the info!
http://77.68.84.201/stream/3/ should be 44Khz 32 bit 256 kbps
where
http://77.68.84.201/;m3u is 44Khz 24bit 128 kbps
http://relaxingjazz.com/ has several different streams of the same music.
Re: RuneAudio+R e6
Posted:
04 Mar 2021, 19:59
by surfninja
this seems to work too
http://77.68.84.201/stream/;m3uI didn't spend a lot of time listening to the station. not my gig.
Re: RuneAudio+R e6
Posted:
05 Mar 2021, 03:19
by marco
Hi All,
I have tried Volumio / Moode and decide to use Rune finally. The sound quality is so good for me. Very appreciate the great works! However, whenever i click the Album, Album Artist and Artist in the library, it is not responding, just stay at the library page, the others such as NAS, Webradio works fine.
I'm running rAudio 1 20210302 on a Raspberry PI 4. I changed the Output_Buffer_Size to 63556 in order to have the correct list of albums. Please Help! Thank you all.
Re: RuneAudio+R e6
Posted:
05 Mar 2021, 15:30
by dmitrich
Hello @rern! I haven't used your product for a while. Recently downloaded and updated the version. I edited the file wlan0 as usual and renamed it to wlan. The first launch went fine. I saw raspberry on the net. But then I rebooted the box (did not add anything to the configuration) and the network disappeared. I connected the monitor and saw that under the barcode the address is 192.168.5.1 and it is not the address received from the dhcp server. Tell me how to fix this? Also, the beta version from the github does not work either.
Re: RuneAudio+R e6
Posted:
05 Mar 2021, 18:10
by surfninja
dmitrich wrote:Hello @rern! I haven't used your product for a while. Recently downloaded and updated the version. I edited the file wlan0 as usual and renamed it to wlan. The first launch went fine. I saw raspberry on the net. But then I rebooted the box (did not add anything to the configuration) and the network disappeared. I connected the monitor and saw that under the barcode the address is 192.168.5.1 and it is not the address received from the dhcp server. Tell me how to fix this? Also, the beta version from the github does not work either.
The 192.168.5.1 is the access point you can use to connect to the Rune for configuration (say you want to setup wifi). you might need to fix your wlan.
i just reloaded from scratch using a USB in place of of the microSD and it worked fine. the system works great so something in your configuration you did isn't working.
Re: RuneAudio+R e6
Posted:
06 Mar 2021, 16:05
by dmitrich
surfninja wrote:The 192.168.5.1 is the access point you can use to connect to the Rune for configuration (say you want to setup wifi). you might need to fix your wlan.
Thanks for the answer. I am aware of the access point. I have a dual band router. I haven't made any configuration changes as I wrote earlier. Today I connected the box via an Ethernet network. This allowed me to configure the Wifi over a 2GHz network. Everything worked right away. If I install 5GHz then after reboot the access point appears and the connection does not work.
Re: RuneAudio+R e6
Posted:
06 Mar 2021, 18:25
by R101
dmitrich wrote: If I install 5GHz then after reboot the access point appears and the connection does not work.
Could this be because the country code is wrong, and your 5GHz channel is not available?
Have you tried
iwlist channel to check?
It might be worth checking the SSID file contents in /etc/netctl too.
Re: RuneAudio+R e6
Posted:
08 Mar 2021, 11:56
by rern
dmitrich wrote:... The first launch went fine. I saw raspberry on the net. But then I rebooted the box (did not add anything to the configuration) and the network disappeared. I connected the monitor and saw that under the barcode the address is 192.168.5.1 and it is not the address received from the dhcp server. Tell me how to fix this? Also, the beta version from the github does not work either.
Try today's update again. Now it forces to reconnect if the 1st attempt failed.
