Page 2 of 4
Re: BBB+RuneOS+I2S
PostPosted: 24 Oct 2014, 08:17
by nautibuoy
Yes, VBBs diagram says it much more eloquently than I can write it.
I believe many DACs can accept either (PCM over) i2s or DSD at their inputs and auto-detect and process as appropriate so it would be very flexible if the Rune software for the BBB could output them on the same pins - no switch required!
Ray
Re: BBB+RuneOS+I2S
PostPosted: 28 Oct 2014, 07:57
by Chanh
VBB wrote:
nautibuoy wrote:....I'll take 'all' to include the dual external clock option functionality so the data retains its native sampling rate. That's good news.
Any thoughts on the PCM - DSD switching question? ....
Ray
A more harmonised interface as shown would be great!:
Hi Andrea and All,
Currently, Miero's BoticOS requires external hardware switches to realign the I2S and DSD signals. It would be great if RuneAudio 0.3-beta would finesse the BoticOS to provide a more harmonised output. This type of interface will gratefully benefit future BBB-RuneAudio user(s) as it seems still a challenge for the hardware guys.
Cheers.
Re: BBB+RuneOS+I2S
PostPosted: 15 Nov 2014, 03:02
by jharp
I hope this post isn't perceived as attempt to "hijack" topic. New to site and was researching use of BBB as an audio player and DAC options, and found this. Could not help but notice and admire gear in Chanh's one post with photos. Could not make out any identifying info on boards and wondering if Chanh would mind providing some info and maybe a link. I assume DAC on bottom and amp boards stacked above?
Thanks!
Jeff
Re: BBB+RuneOS+I2S
PostPosted: 15 Nov 2014, 11:40
by ACX
jharp wrote:Could not make out any identifying info on boards and wondering if Chanh would mind providing some info and maybe a link. I assume DAC on bottom and amp boards stacked above?
Hi jharp,
welcome to the forum. You can find more information about it here.
Re: BBB+RuneOS+I2S
PostPosted: 16 Nov 2014, 02:10
by jharp
Thanks. Wow! Had not heard of combining DACs in parallel like that. The dddac.com site is very interesting.
Re: BBB+RuneOS+I2S
PostPosted: 18 Nov 2014, 04:18
by Chanh
jharp wrote:Thanks. Wow! Had not heard of combining DACs in parallel like that. The dddac.com site is very interesting.
Hi Jeff,
I too await for RuneAudio for BBB. Until that is released, I was able to tweak it with fabulous user interface from Jriver direct LAN connected to BBB. More infor at http://www.diyaudio.com/forums/twisted- ... er-23.html
Apologies for poor video compression.
Best,
Chanh
Re: BBB+RuneOS+I2S
PostPosted: 17 Dec 2014, 22:14
by eragefe
A lot of months passed since my last post and I can see that the creativity never ends here.
Here is something real fun.
I made some prototype pcbs to test botic with external clocks and synchronous resample.
I received them yesterday.
Until now I have not connected the board to my DAC only made some measurements.
The jitter figures looks very promising.
Only one clock is activated for now until I have read some more how to activate the external clock switch on the botic driver.
I will come back with some feedback when I have listened some music. After all it is music all this is about OR?
BRG
Re: BBB+RuneOS+I2S
PostPosted: 17 Dec 2014, 22:43
by ACX
Hi eragefe,
nice to see you again here after a long time :)
Please keep us updated on the BBB+I2S topic as we are going to port RuneAudio to it soon, hopefully including Miero's work.
Re: BBB+RuneOS+I2S
PostPosted: 21 Dec 2014, 21:54
by eragefe
Hi again
Weekend and after a look at Mieros site it was only to enable the switch in the software put together BBB and DAC and start playing music.
What fantastic work that guy have done. Anyway
My first reaction was “what happened?” more details more air more presence.
That DAC have never played like this before. Next track the same.
Hi res. tracks sounds fantastic.
Here I have to tell you that I am using the same external clocks as master clock for the DAC chip.
This is a very experimental setup and I know that I have to implement isolators and buffers to make it more robust
BUT anyway I can’t forget the first question that came up in my head.
WHAT HAPPENED?
Imagine you have a very big complex orchestra there a big section can’t see the conductor.
You solve the problem with another conductor for that section who can see the main conductor and you hope that those two are always in sync.
Should that work? For it is very close to what we do in the digital audio business over and over again.
No I don’t believe it should work.
That’s why one has to simplify effectively reduce the number of instruments and musicians and get ONE orchestra with ONE conductor.
That works.
Thanks Miero one more time for the fantastic work with the driver.
BRG
Re: BBB+RuneOS+I2S
PostPosted: 22 Dec 2014, 03:06
by ACX
This is great news! Finally after many months we have the first concrete results of Miero's huge work, and they are good ones.
How much do you estimate a complete board with isolators and buffers (to avoid damages to the BBB in case of power failure) could cost?
