Re: RuneAudio+R e4
klassikmann wrote:Update Re4 20200724
Custom color: same as yesterday (https://www.runeaudio.com/forum/runeaudio-r-e4-t7084-100.html#p29986)
Oops! Missed that one. Fixed.
Embedded hi-fi music player
https://www.runeaudio.com/forum/runeaudio-r-e4-t7084-110.html
pkdick wrote:...
I have just installed RuneAudio+R e4 on my USBBridge Signature/Katana DAC, but when I activate Chromium nothing is displayed on my HDMI 1920x1080 display from Waveshare ...
I followed the Waveshare advice and I added the following in my config.txt:
max_framebuffer_height=1920
max_usb_current=1
config_hdmi_boost=10
hdmi_group=2
hdmi_force_hotplug=1
hdmi_mode=87
hdmi_timings=1080 1 26 4 50 1920 1 8 2 6 0 0 0 60 0 135580000 3
But it does not help: when I check the status of Chromium using a ssh console, I can only see that it is not started. When I type "startx", I get the fatal error "no screens found(EE)". As I have no programming knowledge, I would be grateful if someone could help me to work out this issue (my screen works on Moode and Volumio, so I assume that it is linked to some missing configuration in RuneAudio).
klassikmann wrote:Update Re4 20200726
The thumbnails in the coverart library view are missing. The entries are present and it's also possible to click on an invisible coverart to select an album.
Edit: After some clicking back and forth the thumbnails are back again.
Edit 2: Some clicks later the thumbnails are gone again, ..., and come back again.
klassikmann
R101 wrote:@rern,
The latest update is working well for me, but the problem of having to choose whether to have the volume control or the cover art on the playback page is still there. If I disable the cover art, the disabled volume control appears.
RolandBlaze wrote:...
Have noticed when streaming from Spotify it displays as being streamed at 48KHz, but Spotify is 44Khz? Can you amend this if poss? I'm aware there may be a few tracks that play at 48Khz on Spotify but very few compared to the amount of 44KHz tracks, and I believe it would be better to set at 44Khz if there is no way to detect what is being provided and automate the change in Rune? ...
RolandBlaze wrote:R101 wrote:@rern,
yup have this also.
