Re: [BugFix] HiFiBerry DAC+ HW Volume (RuneAudio 0.3-beta)
Posted: 23 Nov 2014, 15:30
taizen wrote:Hi ACX,
with control volume in place with Hifiberry dac+ the sound of HiRes (24b 192kHz) has clicks and pause.
Please check if the HiFiBerry DAC+ is the only active output with the mpc outputs command. The behaviour you describe could happen because the Rpi analog output is still enabled and resampling occurs, generating high load on the system.
