Digi+ , Rune and USB drive = channel swapping
Currently having an issue when playing a file (FLAC), the channels will swap several times during a song. Sometimes it's very subtle, while other times it's quite jarring. The issue only occurs when accessing a mounted USB drive source. When accessing a network mounted source, the files play perfectly.
Hardware: RPi3 with Hifiberry Digi+ board. USB powered Toshiba Canvio Connect hard drive and Canakit 5V 2.5A p.s.
Software: beta 4 image (03212016)
This issue has been discussed at the Hifiberry forum
https://support.hifiberry.com/hc/en-us/ ... nd-DAC-Pro
and here, but pertaining to the DAC Pro boards, not the Digi+.
pi3-and-dac-pro-t3293-60.html
Has RuneAudio been able to duplicate this issue, and if so, is RuneAudio also working with Hifiberry on a fix. It sounds like it's a kernel issue and Hifiberry folks are in touch with the Volumio people, so hopefully parallel efforts are going on here.
Thanks and great product.
