Page 1 of 1
Temperature readout in the web interface
PostPosted: 09 Aug 2019, 01:50
by Bignumbas
It would be really good to have a temperature readout in the web interface somewhere with the advent of the pi 4.
Currently I have pi-hole co-installed and that gives it to me and I found vcgencmd in /opt/vc/bin so that helps.
I am running the pi 4 without a case, heatsinks installed and a pifi DAC+ hat and it runs at 34C with a fan blowing in from the card end.
Without it it runs around 44C, I think a case would make this higher plus I am in Australia and its in the middle of winter at the moment.
Max air temp at the moment is around 23C not 30C+
Running Kodi with Netflix on the pi4 resulted in 80C+ and crashing so this iteration is heat sensitive and it is recommended to have a fan
I have another post here on running runeaudio on the pi4 which has photos of my system. Amazingly the sound seems louder and clearer,
Don't know whether I am imagining that or not.
runeaudio-0-5-beta-is-running-ok-on-my-rpi-4b-2gb-t6867.html
cheers
pi-hole temp readout
vcgencmd measure_temp
Re: Temperature readout in the web interface
PostPosted: 09 Aug 2019, 10:51
by janui
PostPosted: 29 Nov 2019, 17:41
by LancerMiG
Has this feature been added in the latest build? Because it'd be an awesome thing to have, as I tend to have temperature issues as well. I've been resorting to jerry-rigged cooling means so far, but I'll use your advice as well, and give feedback about how it goes for me.
