Page 1 of 1
AMP HATs
Posted:
24 Dec 2018, 16:29
by Pete
Rather go with a DAC hat I was thinking of using a AMP HAT so i connect speakers directly.
Which AMP HATs does Rune support?
I found an AMP HAT called just boom which looks good. Is that supported/recommended?
Many thanks
Re: AMP HATs
Posted:
24 Dec 2018, 17:21
by Ears of Tin
I have a Hifiberry Amp2.
https://www.hifiberry.com/blog/introduc ... ffordable/Currrently on the mantle hidden among the Christmas decorations, it's basically invisible. I use a recyled laptop power supply and only one wire to the nearest wall outlet is detectable. The amp drives 8ohm bookshelf speakears. Volume is quite sufficient for a large family room. Typical listen at 20-30% on the runeaudio app.
I'll take a look at the justboom. Looks like they share the same Texas Instument chip. Eventually I'll have one of these in every room plus the garage.
Re: AMP HATs
Posted:
24 Dec 2018, 18:10
by Pete
Thank you. Looks like an option. What size speakers are you powering
Re: AMP HATs
Posted:
25 Dec 2018, 06:34
by Ears of Tin
These:
Boston Acoustics HD-8
Frequency Response (±3dB): 52Hz – 20kHz
Recommended Power Amplifier Range: 10 - 75 watts
Sensitivity (2.83V @ 1m): 90dB
Nominal Impedance: 8 ohms
Crossover Frequency(ies): 3000 Hz
Low-Frequency Driver: 8" (203mm) Copolymer
High-Frequency Driver: CFT 6 1" (19mm) Dome
Dimensions
(H x W x D): 18-1/4" x 11-1/4" x 7-5/8"
(464mm x 286mm x 194mm)
Weight: 16 lb (7kg)
Finish: Wood-Grain Vinyl Enclosure
Black Grille Cloth
Re: AMP HATs
Posted:
26 Dec 2018, 11:09
by Pete
They must sound great. Very nice setup.
