Page 1 of 1
Runeaudio fileserver function?
Posted:
05 Aug 2014, 05:48
by pasdesignal
I may be missing something here, but I have done my best to solve this on my own...
Does runeaudio serve files to a network? Like using Samba as a server or NFS or something?
I am running 0.3 on a Raspberry Pi B+. Loving the performance. Using a homemade USB DAC, MPOD client, airplay.
Just wondering if I can enable the file server somehow....?
(PS: nice work on the distro. Its very tidy and smooth playback - no issues whatsoever with USB DAC output.)
Re: Runeaudio fileserver function?
Posted:
05 Aug 2014, 12:02
by Orion
Hi pasdesignal,
yes. For now, you have to enable the
DEV mode.
Take a look here
http://www.runeaudio.com/forum/post1615.html#p1615
Posted:
10 Aug 2014, 07:52
by pasdesignal
Hi Orion, thanks for the reply.
I tried the "DEV" feature you linked to above, and indeed it did enable a Samba type fileserver. However I didnt have write capability when using the feature as a guest.
Is there a samba user that I should use, or is there a way to enable write permissions for all users on the samba share?
Maybe this idea belongs in "Feature requests". I think it is an important feature because how else is one supposed to add music to our library without unplugging the hard-drive and using another machine. A fully functional samba share with default write permissions is the easiest way to do this, and is implemented on Volumio to great effect.
Interested in your thoughts.
Posted:
13 Aug 2014, 00:11
by ghashul
I have enabled dev mode as described on my rPi b+ with 0.3, but samba doesn't appear to be running. I can't connect from Windows, so I tried logging in via SSH and checked if smbd was running, which it isn't. Is there something more I need to do?
Posted:
17 Aug 2014, 09:52
by franz159
pasdesignal wrote:...I think it is an important feature because how else is one supposed to add music to our library without unplugging the hard-drive and using another machine. .....
If you have your library on an attached USB drive, you might mount the usb drive in r/w mode as explained in
post1724.html?hilit=udevil#p1724Then you can use ftp to upload new music without unplugging the drive.
