Let's try 320x240 3.2inch LCD.
You can buy it from this link.
http://www.hardkernel.com/main/products/prdt_info.php?g_code=G142060963922Add below two line in ~/.bash_profile and save it to load the SPI TFT LCD drivers automatically.
- Code: Select all
modprobe spicc
modprobe fbtft_device name=odroidc_tft32 rotate=270 gpios=reset:116,dc:115 speed=32000000 cs=0
Orginally I tried to add the drivers into /etc/modules-load.d/odroid.conf, it didn't work correctly.
And create a file "/usr/share/X11/xorg.conf.d/99-odroidc-tftlcd.conf" and paste below configuration to display the X11 on the TFT.
- Code: Select all
Section "Device"
Identifier "C1 fbdev"
Driver "fbdev"
Option "fbdev" "/dev/fb2"
EndSection
Save it and reboot, you can see the RuneAudio on the 3.2inch LCD.
Time to calibrate the resistive touch screen. Install the calibrator.
- Code: Select all
pacman -S xinput_calibrator
Run "DISPLAY=:0.0 xinput_calibrator" on the remote shell and follow the instructions.
then, you will get something on the LCD. Follow the instruction on the LCD screen.
You need to use a touch pen and you will have a set of calibration data from the remote console.
- Code: Select all
[root@runeaudio rules.d]# DISPLAY=:0.0 xinput_calibrator
Setting calibration data: 0, 8000, 0, 4800
Calibrating EVDEV driver for "ADS7846 Touchscreen" id=8
current calibration values (from XInput): min_x=0, max_x=8000 and min_y=0, max_y=4800
INFO: width=320, height=240
Doing dynamic recalibration:
Setting calibration data: 208, 3842, 3922, 148
--> Making the calibration permanent <--
copy the snippet below into '/etc/X11/xorg.conf.d/99-calibration.conf' (/usr/share/X11/xorg.conf.d/ in some distro's)
Section "InputClass"
Identifier "calibration"
MatchProduct "ADS7846 Touchscreen"
Option "Calibration" "208 3842 3922 148"
Option "SwapAxes" "0"
EndSection
Run "nano /etc/X11/xorg.conf.d/99-calibration.conf" put the section and save it.
- Code: Select all
EndSection
Now you can control the RuneAudio GUI on the 3.2inch TFT LCD with the touch screen.
