Page 1 of 4
Now officially supported Cubietruck (Cubieboard3)
PostPosted: 14 Apr 2015, 23:06
by hondagx35
Hi all,
Cubietruck (Cubieboard3) is now officially supported by RuneAudio.
Cubietruck is the 3rd board from Cubieteam, they also named it Cubieboard3.
The Cubietruck is basically a PC-on-a-board,
featuring Allwinner’s dual-core ARM Cortex-A7 processor.
With 2GB RAM, WiFi, Bluetooth, Gigabit Ethernet, USB / HDMI
and VGA ports it is a ideal candidate for a music player.
It measures about 4.3″ x 3.1″.
The onboard SATA 2.0 interface enables you to connect
a hard drive or a solid state disk as your music storage.
The actual image is based on the development branch, so it is up to date.
Working features:
* audio
- sunxi-CODEC (3.5mm headphone jack)
- sunxi-sndspdif Toslink (SPDIF Optical)
- sunxi-sndhdmi
- sunxi-sndi2s with hardware modification see here
* IR receiver to adapt your remote modify /etc/lirc/lircd.conf
* sata
* booting from nand a script is available /root/nand-install.sh
The latest image can be downloaded here.
Please report bugs or feature requests in this forum.
Re: Now officially supported Cubietruck (Cubieboard3)
PostPosted: 17 Apr 2015, 05:34
by Chanh
Many thanks for this Frank. I look forward trying it out. :)
Chanh
Sent from my iPhone using Tapatalk
PostPosted: 20 Apr 2015, 12:38
by jfdelaune
Thank you for this release. I have intsalled on CubieTruck. It works very well. I have an SATA disk intsalled (sda). How to see the disk in RuneAudio ?
PostPosted: 20 Apr 2015, 15:50
by hondagx35
Hi jfdelaune,
I'm working on a solution for this.
For now you have to mount it manually.
- Got to the terminal or ssh into your CT.
- enter
ls /dev/sd*
to find the sata device name. Output should be something like:
/dev/sda  /dev/sda1
- enter
mount /dev/sda1 /mnt/MPD/LocalStorage
Change the device name to fit yours.
To make this permanent:
edit /etc/fstab and add the last line
# /etc/fstab: static file system information
# <file system>   <dir>   <type>   <options>   <dump>   <pass>
logs            /var/log                tmpfs           nodev,nosuid,noatime,mode=1777,size=5M                  0       0
rune-logs       /var/log/runeaudio      tmpfs           nodev,nosuid,noatime,mode=1777,size=5M                  0       0
Do not boot your device with a usb stick in it, because device names may change.
A better solution comes soon.
PostPosted: 26 Apr 2015, 14:08
by jfdelaune
It works very well.
PostPosted: 01 May 2015, 11:12
by kajica
Thanks on the great work on this rtelease,
works great !!!
only issue im having is not being able to mount my NAS. I have both LCH Buffalo and QNAP wichich both im not able to mount.
if anyone has succesfuul mounting plaese share your info how you did it
much appreciated, thanks again
kai
PostPosted: 01 May 2015, 17:59
by hondagx35
Hi kai,
Can you provide us more info please:
- error message (on the source page click your NAS mount, the error message is on the top of the page)
- NFS or SMB?
- if possible post your rune_SY_wrk.log via pastebin. (/var/log/runeaudio/rune_SY_wrk.log)
PostPosted: 01 May 2015, 21:19
by kajica
Hello Frank,
thanks for your reply here is my info NAS SMB
NAS MOUNT SOURCES
Screen Shot 2015-05-02 at 4.00.14 am.png (83.52 KiB) Viewed 10606 times
[01-May-2015 19:54:57 UTC] ### sysCmd($str) ###  mkdir "/mnt/MPD/NAS/MUSIC"
[01-May-2015 19:54:57 UTC] ### sysCmd() output: ### $data type = array
[01-May-2015 19:54:57 UTC] ### mount string ###  mount -t cifs "//192.168.1.8/DataVol1/MUSIC/" -o username=admin,password=password,sec=ntlm,soft,uid=1000,gid=1000,rsize=16384,wsize=17408,iocharset=utf8,cache=none,noserverino,ro "/mnt/MPD/NAS/MUSIC"
[01-May-2015 19:54:57 UTC] ### sysCmd($str) ###  mount -t cifs "//192.168.1.8/DataVol1/MUSIC/" -o username=admin,password=password,sec=ntlm,soft,uid=1000,gid=1000,rsize=16384,wsize=17408,iocharset=utf8,cache=none,noserverino,ro "/mnt/MPD/NAS/MUSIC"
[01-May-2015 19:54:57 UTC] ### sysCmd() output: ###  ['0'] => mount error(22): Invalid argument
[01-May-2015 19:54:57 UTC] ### sysCmd() output: ###  ['1'] => Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
[01-May-2015 19:54:57 UTC] ### system response ###
[01-May-2015 19:54:57 UTC] ### sysCmd($str) ###  rmdir "/mnt/MPD/NAS/MUSIC"
PostPosted: 01 May 2015, 22:16
by hondagx35
Hi kajica,
please try to change the mount options like this
The problem may be the option
cache=none
SOLVED (no chache was the problem)
PostPosted: 02 May 2015, 04:58
by kajica
thanks for suggestion
this is what i get
Retrying with upper case share name mount error(6): No such device or address Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
if i make it NFS
i get this error
mount.nfs: access denied by server while mounting 192.168.1.8:/DataVol1/MUSIC/
