Here to help with development and idea's
Hi my name is Corey I am a experienced user of Linux and love Rune Music OS on my Raspberry PI and want to help with idea's, support and feedback or bug reports. So far everything has gone great the only things I have to say need fixing and needing to be added are:
Ability to add username and password or just password protection so no one can access it and muck around with it while your using on the network
fix runeaudio.local to work on Android phones while its plugged in via LAN as it does not detect or able to connect to in via Android device only on laptops it can use Android.local at this state. I am also making a Android app so you can use and control it via Android but I need runeaudio.local to work before it can properly work, I have a test app I have been using only connecting to a certain ip address and it works perfectly so if that can be addressed than I can finish the app.
And finally fix the bug that screws the connection forcing you to re install Rune Audio when trying to set it to a static address doesn't correctly work and I have tried multiple times and when reconnecting to it via the new static address with everything correctly written in I can no longer connect nor does it appear in my network at all even looking on connected devices on my modem.
Anyway's everything working pretty great right now and I hope to see thing progress real fast and do a lot of wonders for everyone needing a cheap audio station.
Here are images of the app I made working on Android.
