i found a way to run runeaudio on a rpi 3 B+
I did it in an ampiric way, using two rpi. A rpi 3 and a rpi 3B+.
On the rpi 3, I used the 0.4b hondagx35 version, I wanted to have an on-screen display.
https://docs.google.com/uc?id=0B5E5WDN-EI9Lc3ZzVEcwWDE0LUE&export=downloadExtend the partition:
http://www.runeaudio.com/documentation/troubleshooting/extend-partition-sd/but for me i have to write:
- Code: Select all
resize2fs /dev/mmcblk0p2
at the end for work.
I have installed the addons of rern (with Putty).
http://www.runeaudio.com/forum/addons-menu-install-addons-the-easy-way-t5370.html#p22376Update the mpd, midori in the webui addons.
after i update the kernel using the soluce of hondagx35
http://www.runeaudio.com/forum/runeaudio-0-4-beta-for-raspberry-pi2-3-t4434-390.html#p23950. I don't know why, but after the update, the option to enable i2s disappear.
I supose you have to enable i2s and choose the audio card before the kernel update.
It's not a problem for me, i have an usb dac.
And after all that, I put the microsd in the rpi 3 b+, and it works for me!!!
