Posted: 07 Nov 2017, 13:15
Hi Frank
Any thing new about new kernel update? Digione still need new kernel.
Embedded hi-fi music player
https://www.runeaudio.com/forum/
https://www.runeaudio.com/forum/runeaudio-0-4-beta-for-raspberry-pi2-3-t4434-360.html
thanhvo31 wrote:Hi Frank
s.k. wrote:Very good news !!!
Thanks !
Is it possible todo the same upgrades on the version of this post (0.4beta)?
wget -qN --show-progress https://github.com/rern/RuneAudio/raw/master/rankmirrors/rankmirrors.sh -P /usr/local/bin; chmod +x /usr/local/bin/rankmirrors.sh; rankmirrors.sh
pacman -Sy linux --force --noconfirm
dtoverlay=allo-digione
pacman -Sy linux —force —noconfirm
error: target not found: —force
error: target not found: —noconfirm
s.k. wrote:Hi thanhvo31 & Thanks for your support
Although I don’t have the DigiOne (I have the Digi+ pro) I tried to update the kernel according to your instructions, over a clean installation of Frank,s version (RuneAudio_rpi2_rp3_0.4-beta_20170229_2GB) .
The command
- Code: Select all
gave back
- Code: Select all
Any clue?
uname -r
redis-cli get hwplatformid
cd /srv/http/
git pull
git checkout 0.4b
pacman -Syy --force raspberrypi-firmware raspberrypi-bootloader linux-raspberrypi linux-firmware cifs-utils
pacman -Q linux-raspberrypi
uname -r
redis-cli set kernel "Linux runeaudio 4.9.??-1-ARCH"
nano /srv/http/db/redis_datastore_setup
redis-cli get kernel
redis-cli get buildversion
redis-cli set kernel <newvalue1>
redis-cli set buildversion <newvalue2>
pacman -S libsndfile
pacman -S --force openssl pacman wpa_supplicant
php -f /srv/http/db/redis_datastore_setup check
php -f /var/www/command/refresh_nics
pacman -Sy readline
ln -s /usr/lib/libncursesw.so.6 /usr/lib/libncursesw.so.5
ln -s /usr/lib/libreadline.so.7 /usr/lib/libreadline.so.6
