Hi RuneAudio!
I am a Windows-Noob and it is difficult for me to copy files via ssh to the pi.
Because of that, I had the following idea:
Is it possible to use the Samba-Fileshare, for example, to copy the Webradio.pls-Files in the default-folder /mnt/MPD?
Or is it possible, to create a import-directory manually for the MPD, so that I can change it to the samba-folder e. g. /192.168.1.1/sd?
Thanks for your reply.
PS: In the docs (https://www.runeaudio.com/documentation ... art-guide/), the password is rune. Could you change this to ros. Thanks!
Regards!
