Page 1 of 1
No Wifi LAN Connection PI Zero 2W
Posted:
09 Jan 2022, 15:44
by Sonntagsbastler
I have installed the 64bit i20211203 Image on a my Raspberry PI Zero 2 W (with Hifiberry Dac+) but I cannot get Raudio-1 connected to my wireless network, and thus neither connected to the Internet. I assume this is because my router's IP address is 192.168.5.1, which is the same as the hoptspot default IP address to which I can connect from my mobile phone. I tried to change the hotspot IP address to 192.168.6.1 which did not work.
Maybe this issue has already been addressed in one of the updates. Unfortunately my knowledge of Linux is too limited to understand how to install these updates. Your help would be very much appreciated.
Bruno
Re: No Wifi LAN Connection PI Zero 2W
Posted:
10 Jan 2022, 10:22
by Sonntagsbastler
After flashing the 20211203 image at least ten times and copying an edited wifi file to the boot drive I could finally connect to my wireless lan. My assumption that the network connection was not working due to the hotspot IP address conflicting with the router's IP address was wrong.
Bruno
Posted:
24 Jan 2022, 20:17
by Max Payload
I did about the same, downloaded the rAudio-1-RPi0-1-20220116.img (as recommended) and put it on an Micro-SSD with Balena Etcher, copy the WiFi file (with correct data) to BOOT. The light of the Pi Zero-2W comes on, flashes 2 times then stays on. That's it. No WiFi, no way to connect. Re-downloaded the file 4 times and re-flashed but just not working at all. Nothing on the attached screen as well. Probably the Zero 2W is to new? Works out of the box with Volumio but that new 3.x version has no "autostart" so i would give RuneAudio a test. Any solutions?
Posted:
25 Jan 2022, 09:28
by rern
Max Payload wrote:I did about the same, downloaded the rAudio-1-RPi0-1-20220116.img (as recommended) ...
For
Zero 2: rAudio-1-
64bit-20220116.img.xz,
not rAudio-1-
RPi0-1-20220116.img.
Posted:
09 Mar 2022, 09:52
by yanisroy
Did you change the country code when you did ctrl+shift+x? It is a bit hard to notice that
get-shareit.com get-vidmateapk.com
