Page 48 of 51
Re: RuneAudio+R e6
PostPosted: 10 Sep 2021, 13:38
by chasolla
Please accept my apologies.
I am on https://github.com/rern/rAudio-1
No neither the dice or the crossed arrows are highlighted. I think that the crossed arrows only shuffle once anyway.
As I said it happened after the last update.
I've tried lots of reboots but it doesn't change.
Is there a restore factory settings button anywhere?
The only way that I can cope at the moment is where it deletes a track from the playlist after it has played.
Otherwise it would just keep playing tracks from the current playlist endlessly.
I think that I'll try a fresh install and hope that it doesn't happen again.
Thank you for all your great work.
Chas
Re: RuneAudio+R e6
PostPosted: 11 Sep 2021, 18:17
by The Shocker
rAudio 1 • 202109032
How do I get the VU meter to move?
I added the VU meter to my Now Playing screen. but he arrow just sits all the way to the left and never moves.
Re: RuneAudio+R e6
PostPosted: 31 Oct 2021, 15:20
by philauss
I am almost done with the installation of RuneAudio Re6, I can access to the interface using LAN connection (not wifi), but I have an issue when I click on system, i get this message:
Errors: Unexpected token ] in JSON at position 1259
{ "page" : "system" , "cpuload" : "0.21 0.08 0.02" , "cputemp" : 56.0 , "startup" : "4s (kernel) + 12s (userspace) " , "throttled" : "0x0" , "time" : "14:09:16 2021-10-31" , "timezone" : "UTC" , "uptime" : "8m" , "uptimesince" : "2021-10-31 14:01" , "audioaplayname" : "" , "audiooutput" : "" , "bluetooth" : false, "bluetoothconf" : [ true, false ] , "firmware" : "20211004-1" , "hostapd" : false, "hostname" : "rAudio" , "kernel" : "5.10.74-1-raspberrypi4-ARCH aarch64" , "lcd" : false, "lcdchar" : false , "lcdcharaddr" : "0x27 0x3F" , "lcdcharconf" : [ 20,"A00","i2c","0x27","PCF8574",15,18,16,21,22,23,24,false ] , "list" : [ {"icon":"microsd","mountpoint":"/","mounted":true,"source":"/dev/mmcblk0p2","size":"3.0GB/30GB"} ] , "lcdmodel" : "tft35a" , "mpdoled" : false , "mpdoledconf" : 6 , "online" : true , "ntp" : "pool.ntp.org" , "powerbutton" : false, "powerbuttonconf" : [ 5,40,5 ] , "relays" : false , "rpimodel" : "Raspberry Pi 4 Model B Rev 1.1" , "soc" : "BCM2711" , "soccpu" : "4" , "socram" : "3.7GiB" , "socspeed" : "1500" , "soundprofile" : false , "soundprofileconf" : [ 18000000 ,60 ,1500 ,1000 ] , "version" : "1" , "versionui" : 20211020 , "vuled" : false , "vuledconf" : [ 14,15,18,23,24,25,8 ] , "wlan" : true , "wlanconf" : [ "NO" , ▮] , "wlanconnected" : false}
And make impossible to setup wifi, UPnP etc. I am stuck here.
Any idea?
thank you very much
Philippe
Re: RuneAudio+R e6
PostPosted: 04 Nov 2021, 00:16
by Ears of Tin
Re: RuneAudio+R e6
PostPosted: 04 Nov 2021, 17:16
by philauss
Ears of Tin wrote:Use this:
Thank you very much, it might help ;)
Super, now I have access to system and can do any modification I want. I can connect the device to the wifi, play webradio it is fine. I try to activate UPnP to connect BubbleUpnp to the device but it does not work. I get this message:
upmpdcli 1.5.12-1
● upmpdcli.service - UPnP Renderer front-end to MPD
Loaded: loaded (/usr/lib/systemd/system/upmpdcli.service; enabled; vendor preset: disabled)
Drop-In: /etc/systemd/system/upmpdcli.service.d
└─override.conf
Active: activating (auto-restart) (Result: exit-code) since Sat 2021-11-06 14:44:21 CET; 37s ago
Process: 14882 ExecStart=/usr/bin/taskset -c 3 /usr/bin/upmpdcli -c /etc/upmpdcli.conf (code=exited, status=1/FAILURE)
Main PID: 14882 (code=exited, status=1/FAILURE)
CPU: 34ms
Thank you
Sorry again ;-)
Philippe
Re: RuneAudio+R e6
PostPosted: 06 Nov 2021, 14:50
by philauss
upmpdcli 1.5.12-1
└─override.conf
CPU: 34ms
I forgot to mention that I want to use BubbleUPnP for Android with my tidal account and use RuneAudio as a DLNA render device.
thank you very much,
Re: RuneAudio+R e6
PostPosted: 12 Nov 2021, 06:41
by alphab0t
hello. have been running this version on my pi4 with official touchscreen daily for several months.
Today the comcast internet was down, but to be clear my local network was fully functional. It should have had zero trouble connecting to that.
For some reason the Rune install hung on boot and would not finish. I eventually had to power it down but I tried it several times and found the same result. I almost thought I had to reinstall but decided to wait and see.
Few hours later and comcast is back, the Rune Pi4 booted up properly.
What is this reliance on the internet? If that's not it, what else causes this behavior?
Re: RuneAudio+R e6
PostPosted: 16 Nov 2021, 11:34
by Beelzebassie
A small bug: when setting the replay-modus to 'all', refreshing the page (F5 - Firefox) will show the 'shuffle' and replay 'single' icons. The player will continue to replay all continuously nonetheless.
And since a few iterations back, online cover art is no longer loaded - also shown in attached pictures. Can someone confirm this?
Re: RuneAudio+R e6
PostPosted: 26 Nov 2021, 16:55
by psykoknarf
hi all.
excuse my possible stupid question, but... where is the iso file for this version of RuneAudio? looking for it everywhere but impossible to find
Thanks a lot in advance
Re: RuneAudio+R e6
PostPosted: 27 Nov 2021, 04:51
by rastus
