Page 5 of 51
Re: RuneAudio+R e6
PostPosted: 26 Oct 2020, 09:11
by Russ
Hi Rern and everyone,
I am still having problems with wifi setup on Raspberry Pi Zero. It is the same problem as last time which it manage to resolve with downloading a fresh image. However, I came about the same problem with one of my Pi3 installation two months ago but resolved after a few tries. Now again, I am struggling with the wifi setup for past two days with two Pi0s and with multiple downloads of the e6 image over two PCs. The error on journalctl -xe is as follows:
RARe6-Pi0:~  #  journalctl -xe
-- A start job for unit netctl@FW.service has begun execution.
-- The job identifier is 3496.
Oct 26 15:39:10 RARe6-Pi0 network[7647]: Starting network profile 'FW'...
Oct 26 15:39:10 RARe6-Pi0 network[7647]: The interface of network profile 'FW' is already up
Oct 26 15:39:10 RARe6-Pi0 systemd[1]: netctl@FW.service: Main process exited, code=exited, status=1/FAILURE
-- Subject: Unit process exited
-- Defined-By: systemd
-- Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- An ExecStart= process belonging to unit netctl@FW.service has exited.
-- The process' exit code is 'exited' and its exit status is 1.
Oct 26 15:39:10 RARe6-Pi0 systemd[1]: netctl@FW.service: Failed with result 'exit-code'.
-- Subject: Unit failed
-- The unit netctl@FW.service has entered the 'failed' state with result 'exit-code'.
Oct 26 15:39:10 RARe6-Pi0 systemd[1]: Failed to start Networking for netctl profile FW.
-- Subject: A start job for unit netctl@FW.service has failed
-- A start job for unit netctl@FW.service has finished with a failure.
-- The job identifier is 3496 and the job result is failed.
Oct 26 15:39:10 RARe6-Pi0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=netctl@FW comm=">
Oct 26 15:39:10 RARe6-Pi0 kernel: audit: type=1130 audit(1603697950.570:614): pid=1 uid=0 auid=4294967295 ses=429496729>
lines 1572-1600/1600 (END)
I actually got the wifi up the other day (I was messing about with the Access Point but I could not replicate it again.) But it was missing SMB and the option switch so I re-flash the card. (Only later to find the option toggle for it was moved to a different page. :ugeek: )
All I know is that it has nothing to do with setting it through /boot/wifi or using wifi-menu or the Network option page on the web interface. It has a lot to do with the systemd netctl@xxx process exiting on error code. The above error has always been the case since RuneAudio+Re4.
And yes, I did managed to get wired connection up using a USB hub and a USB LAN adapter.
Here's more info:
RARe6-Pi0:~  #  netctl status FW
* netctl@FW.service - Networking for netctl profile FW
     Loaded: loaded (/usr/lib/systemd/system/netctl@.service; static)
     Active: failed (Result: exit-code) since Mon 2020-10-26 15:39:10 +08; 24min ago
       Docs: man:netctl.profile(5)
    Process: 7647 ExecStart=/usr/lib/netctl/network start FW (code=exited, status=1/FAILURE)
   Main PID: 7647 (code=exited, status=1/FAILURE)
Oct 26 15:39:10 RARe6-Pi0 systemd[1]: Starting Networking for netctl profile FW...
RARe6-Pi0:~  #  systemctl restart netctl@FW.service
Job for netctl@FW.service failed because the control process exited with error code.
See "systemctl status netctl@FW.service" and "journalctl -xe" for details.
RARe6-Pi0:~  #  netctl reenable FW
'/etc/systemd/system/multi-user.target.wants/netctl@FW.service' -> '/usr/lib/systemd/system/netctl@.service'
generated '/etc/systemd/system/netctl@FW.service.d/profile.conf'
RARe6-Pi0:~  #  netctl start FW
RARe6-Pi0:~  #  cat /etc/systemd/system/netctl@FW.service.d/profile.conf
[Unit]
Description=Automatically generated profile by wifi-menu
BindsTo=sys-subsystem-net-devices-wlan0.device
After=sys-subsystem-net-devices-wlan0.device
Re: RuneAudio+R e6
PostPosted: 26 Oct 2020, 09:29
by Russ
Hi again guys,
Just to let you know that the wifi now works. I rebooted after all those reset commands listed above and when I tried again to connect to network, it detects the profile already existed (it did not before) and popped up a connect/forget option. Connected successfully. Now hopefully, there will be no issues on my home wifi later on.
While it resolves itself again this time, I would think there should be a longer term solution to this intermittent problem.
Re: RuneAudio+R e6
PostPosted: 26 Oct 2020, 09:54
by R101
Hi rern,
After today's update, the system settings are not accessible from the menu.
Re: RuneAudio+R e6
PostPosted: 26 Oct 2020, 09:58
by Russ
R101 wrote:Hi rern,
Yups, same here.
Re: RuneAudio+R e6
PostPosted: 26 Oct 2020, 11:31
by klassikmann
@R101 @Russ
Which settings do you miss?
The Features (Renderers, Streamers, ...)? They have their own icon in the menu now.
klassikmann
Re: RuneAudio+R e6
PostPosted: 26 Oct 2020, 11:57
by ceejayemm
@rern / @klassicmann
I too can confirm that after todays update the main System page is not accessible (not the new Features submenu).
Chris
Re: RuneAudio+R e6
PostPosted: 26 Oct 2020, 12:02
by Beelzebassie
To be specific: it's the "/index-settings.php?p=system" page that does not get loaded.
Re: RuneAudio+R e6
PostPosted: 26 Oct 2020, 12:28
by klassikmann
Beelzebassie wrote:To be specific: it's the "/index-settings.php?p=system" page that does not get loaded.
Can't confirm. Both pages are accessible here:
.../index-settings.php?p=system
.../index-settings.php?p=features
Hm?
klassikmann
Re: RuneAudio+R e6
PostPosted: 26 Oct 2020, 12:56
by RolandBlaze
@Rern
@RolandBlaze, @s.k. and @kiko,
Please remove the buffer tweak and update Library again.
Have done this, the scan now finishes (It finished for me btw with just the buffer tweak and without the patch / new cmd script), but again now only 4 entries in "Albums" (had over 27,000 when the buffer tweak was still in place). Appears this buffer tweak is needed for me to see more than 4 albums in "Albums".
.../index-settings.php?p=system > Broken for me.. flashing rune logo
.../index-settings.php?p=features > works fine
Roland.
Re: RuneAudio+R e6
PostPosted: 26 Oct 2020, 13:15
by rern
R101 wrote:After today's update, the system settings are not accessible from the menu.
Please post outputs:
/srv/http/bash/system-data.sh
/srv/http/bash/system-data.sh | jq .
