Page 35 of 46
Re: RuneAudio+R e6
PostPosted: 16 Jan 2021, 19:57
by guermantes
So, next question... :-)
(installed rAudio 1)
Albums that are stored in CD1, CD2, CDxx... folder structures are truncated when moved to playlist. But all files are indexed and in the database because the album view shows tracks from all subfolders with this proper ID3 unique numbering.
Wagner - Der Ring des Nibelungen (Thielemann) 24-96\
---Die Walküre 24-96
---CD1
---CD2
---CD3
---CD4
Only tracks from CD1 gets inserted into the playlist.
For example, the structure with 4 subfolders and 43 tracks total with ID3 track numbers from 1-43 but in each subfolder the files are numbered beginning with 1. I presume that flips mpd up in some sense, and it was like this also when I was using janui's runeAudio 05-beta with your addons, but not when using the runeaudio 05-beta vanilla. So it's something in the @rern implementation that creates this problem. Do you have an idea about how it can be fixed?
Re: RuneAudio+R e6
PostPosted: 17 Jan 2021, 00:43
by kiko
When I rip mulit discʻs I use the ID3 tagging such that disc 1 song one is 01-01, and disc 4 song 10 is 04-10. This way the songs play the way you expect them.
Re: RuneAudio+R e6
PostPosted: 17 Jan 2021, 09:10
by dror
Any way to minimize micro-sd card writings to avoid a failure?
My current experience is a very stable setup (BT works great, mount is detected, web interface responsive), so I would like to preserve this for as long as I can :)
Thanks,
Dror
Re: RuneAudio+R e6
PostPosted: 17 Jan 2021, 17:06
by cmh714
Just take an image of it when you have it all setup. That way you just put it on a new card.
Re: RuneAudio+R e6
PostPosted: 18 Jan 2021, 07:57
by dror
cmh714 wrote:Just take an image of it when you have it all setup. That way you just put it on a new card.
Thanks, but what I meant is I prefer avoiding a corrupt card.. seems to happen too occasional to me
Re: RuneAudio+R e6
PostPosted: 18 Jan 2021, 11:28
by eziodavinci
Hi everyone,
I have problem with accessing SD card. I cannot click to go inside SD card to browse my library. I try to flash again 2-3 times but no help. Does anyone facing to similar problem?
Thank you in advance.
https://www.upsieutoc.com/image/8FJoGp
Re: RuneAudio+R e6
PostPosted: 19 Jan 2021, 09:24
by rern
dror wrote:Any way to minimize micro-sd card writings to avoid a failure?
Backup Micro SD Card to Image File
Re: RuneAudio+R e6
PostPosted: 19 Jan 2021, 12:00
by dror
As I answered @cmh714 suggestion, my intention was to reduce the micro-sd card writes, to avoid a failure. The backup is nice, but I want to prevent a corrupt SD (happened to me too occasionally).
I remember there was a discussion about this with instructions, but I can't find it, nor could I be sure this would work with your build.
Dror
Re: RuneAudio+R e6
PostPosted: 20 Jan 2021, 03:04
by rastus
So this is the latest rern version?
Re: RuneAudio+R e6
PostPosted: 20 Jan 2021, 03:46
by cycl157
rastus wrote:So this is the latest rern version?
Latest version information can be found here: https://github.com/rern/rAudio-1
Latest announcements and discussions can be found here: https://github.com/rern/rAudio-1/discussions
